Aussieveedubbers 路 Tech Talk
Earthing gearbox - solid mounted
https://forums.aussieveedubbers.com/threads/93535/earthing-gearbox-solid-mounted
Aussie Dubbin 路
Hi guys,
i have a solid mounted reaer cradle, does it need the earth strap that usually comes off the nose cone?
I would assume not.
Cheers Aaron
HappyDaze 路
My transmission is mounted solid - but I still fit the earth strap. Why not?
Nothing worse than a bad earth, as it can cause all sorts of electrical woes, least of all sluggish starting.馃憥
AA003 路
Bad earths cause a lot of problems. I'd fit it.
Sides 路
AA003 wrote:Bad earths cause a lot of problems. I'd fit it.
x3
Especially with that decent coat of paint you gave your pan and frame horns... only thing better than that for giving bad earth's would be rust and or powder coating.
Earth strap weighs what... half a kilo tops ???
Aussie Dubbin 路
Fair points lads. Cheers
shaihulud 路
When you are re-fitting the earth strap, clean all surfaces of the strap and all of the nuts, washers and bolts and where the strap will touch the pan and gearbox, down to shiny clean metal and liberally apply Glycerene to all surfaces before assembly.
It will never corrode and will give a very good reliable earth.
68AutoBug 路
Aussie Dubbin wrote:Hi guys,
I would assume not.
Cheers Aaron
YES AARON
the only way to be 100% sure that the earth is connected is to use the Earth strap...
starter problems-
headlamp brightness-
charging problems-
all can be caused by NOT using an earth strap..
I would replace the old one with a new one...
clean under where its going to go... wire brush ..
and the same on the chassis... I always use a NEW bolt and nut where it bolts to the chassis..
everything shining where the bolts/threads go...
