11CAB wrote:What was the reason for the engine being out in the first place?
As far as I can make out the engine was pulled to change the clutch. Both the friction plate and pressure plate were missing. Almost looks like they've gone to buy new ones and never come back. So fingers crossed it will run with no issues.
On Sunday I got everything hooked up. Had to pulled the starter motor out and give it a thorough clean out. It just had no grunt whatsoever.
Engine turns over fine without worries, pumped up oil pressure.
I was having issues with the fuel pump not working. The problem is somewhere in the relay setup. So I hard wired it to the battery and the pump works fine. Too the return line off and ran fuel through the rails.
Turned it over and she will not fire.
Checked a plug lead and she's not getting spark.
Gave the rotor and dizzy contacts a clean off (had already set the points on Saturday) and now she's getting a reasonable spark.
Still won't fire.
I rang Dave and got a consult and he seems to think that the injector needles might be jammed, failing that the ECU might not be sending or receiving the signal to fire.
Anyone else have any other ideas??
Smiley
馃檪
