Can anyone tell me the best angle to lay my beam back to get my caster right????????
11CAB ·
What's wrong with castor shims?
whathaveidone ·
already have them in and its not enough!!!!
dangerous ·
My car was sweet to 147mph with just i set, perhaps the wheels are not pointing straight ahead?
7 to 9 degrees of caster should be more than you would ever need.
whathaveidone ·
Cheers Dave. Wheel alignment is good. Ive been told with the rake Ive got is the problem. Should i go off a level surface or off the pan???
Dak-A-Tak ·
Sounds like maybe the rear is walking the car around , which is a very common problem !
whathaveidone ·
Whats the best way to deal with that???? The car is very unsteady at the moment!!!
dangerous ·
Measure you caster first to make sure it is not bogus with so much rake.
This needs to be done in relation to the ground.
The top of your tunnel is a good reference to use when doing the cut.
You really need to make sure that your rear wheels are pointing the right way.
Early cars with late trans always struggle to get any toe in,
so you may have to shim the front trans mount.
I like a little toe in when the axles are dead level...but it must be centred to the front wheels.
so....
Get it on a machine to make sure the rear is in the same plain as the front.
Another problem with so much lowering, is the tie rods get into a position that has a lot of bump steer.
You can do all sorts of things to improve the situation,
like moving the tie rod ends, or making up a single tie rod and connecting track rod deal.
...but if you raise the front back to stock, and then do a small pie cut, you can get:
good caster(dont go too far),
car WILL be lower,
and with stock trailing arm angle,(in relation to the beam)
your bump steer will be reduced.
JVLRacing ·
Is the car actually steerin straight or is it pullin u to one side as u hitting a certain speed?
if so check ur steering arm angles....
mactaylor ·
good question! what is the set up for most of the aussie swing axle link pin pan cars?
nbturbo ·
whathaveidone- Did my PM get thru to you?
Dak-A-Tak ·
Go and see Maca , I'm sure he has the BERG tech book .
whathaveidone ·
Nturbo- yes it did, havent been able to check it for a few days
Pete- Ive been talking alot to Henry. He has given me quite a list of things to check. BERG book sounds interesting though, will try to track it down.
Thanks guys
hellbugged ·
Dak-A-Tak wrote:Go and see Maca , I'm sure he has the BERG tech book .
X2 I can send mine down if you need
whathaveidone ·
What is the exact name of the book???? might be a good one to own. Looked on the berg site and there is a few.
Some mod thought it was worth deleting my description of the Gene Berg Book of Technical Articles as the Gene Berg Tech Book ....WTF is happening here!!!!
Dak-A-Tak ·
Maybe the powers of be , can set up a section at top of vw dragracing area for tech storys so people can get help easy !!
