Aussieveedubbers · Bugs
1969 auto beetle
https://forums.aussieveedubbers.com/threads/93751/1969-auto-beetle
BugsyMalone ·
My beetle arrived today thanks to Bushed(Berni), although being a auto the shifter looks alot like a manual shifter. So what is the shift pattern???? I had it in a forward gear, not sure which one, but it had a hell of a time climbing my driveway, which aint that steep?
Can anyone help me out????
BugsyMalone wrote:My beetle arrived today thanks to Bushed(Berni), although being a auto the shifter looks alot like a manual shifter. So what is the shift pattern???? I had it in a forward gear, not sure which one, but it had a hell of a time climbing my driveway, which aint that steep?
SOUNDS LIKE DRIVE 2 GEAR... it has LOW Drive 1 Drive 2
I;ll see if I can find the diagram... on My ashtray...
normally You use LOW for Your driveway...
Drive 1 & drive 2 on the road.. although Low gets You going fast... lol
REVERSE................................................. DRIVE ONE
push down and forward .............NEUTRAL
LOW GEAR .................................................DRIVE TWO
IN TRAFFIC i LIKE TO START OUT IN low GEAR AND BEAT THE OTHER CARS AND THEN GO INTO DRIVE 2....
the 3 gears are the same as 2nd 3rd and 4th in a manual transmission. 1st gear is not needed...
clutch doesn't slip.... its either IN or OUT...
this happens every time You move the gearshifter forwards or backwards..
My autostick websites....
pod ·
and remember to keep your hand off the gearstick when you are not changing gear
Pumba ·
And keep your foot flat to the floor at all times😂
BugsyMalone ·
Cheers guys, look forward to cruising with you all hopefully soon!
pod ·
Pumba wrote:And keep your foot flat to the floor at all times😂
lol they are not that bad Shane ,drive it like a manual and you will be alright
Pumba ·
To be honest paul i have never driven one.
Here's the semi auto page from 74 superbug.
It's all the same shit different bucket except yours won't have the PARK position.
BugsyMalone ·
Thanks Joel, diagrams good.
Smiley ·
Joel wrote:Here's the semi auto page from 74 superbug.
And you will have to push the gearstick down before putting it into reverse position for it to go into gear.
Smiley 🙂
Ah yes right you are smiley, it's been too long since I've driven one.
I shoulda just looked harder, heres the one for 68-70 1500 semi auto.
BugsyMalone ·
Cool, thanks for all the help. with the diagram and the text, I should be able to get it in the right gear to drive it up my driveway 👍
Pumba wrote:To be honest paul i have never driven one.
I will have to do a video of My beetle driving...
they do go very good..
especially with the bosch SVDA single vacuum dual advance distributor ...
