Aussieveedubbers 路 Tech Talk
running lean on one cylinder
https://forums.aussieveedubbers.com/threads/93807/running-lean-on-one-cylinder
bugzla 路
okay i have kadrons and its running lean on one cylinder only and rich on the other any hints what might be causing this ... the inlet gasket has been glued on and it still does it 馃槀
bugzla 路
bump
Sides 路
Let me guess... it's either #1 or #3 that's running lean with the balance tube connection on the manifold ???
If so just block the balance tube off and see if helps.
馃憤
bugzla 路
i wish ......................its number 4 cylinder
Lucky Phil 路
I'd be checking for a blocked jet
Bizarre 路
He is running Kads Lucky Phil - rules out blocked jets 馃檨
bugzla 路
just when i think ive solved the problem it comes back again i think its almost got the better of me 馃檨
