Hi There,
I'm curious, what the difference is with IDF and IDA carbs and which is the better of the two??
Looking at a new set for christmas..!
Jason
Craig S 路
Here is the blind leading the blind...
I believe that IDFs have a better idle circuit and are therefore easier to live with every day and make more progressive power.
IDAs are more rough at lower revs, but I believe that outright they make more power than IDFs. Or more precisely, when matched with an appropriate camshaft and lifter combo, will make more power.
Therefore for any racing (drag or circuit) where revs will remain high and idle smoothness is not important, IDAs are the best option.
There are obviously those who are more than happy to live with IDAs on a street machine however.
Whilst IDAs in of themselves may not drink more petrol, when set up with the appropriate engine components to obtain the optimum performance, they can drink like a fish.
Thanks for the Links!!! looks like now i just need to work out what size to get 44's or 48's
Sides 路
General rule I've heard in a few places is 1600-1800, use 40's.... 1800-2000, go 44's and for 2000+ go 48's... and then go different size venturi's to fine tune to heads, cam etc.
Whatcha been running up till now ???
snitz 路
What sort of motor?...capacity etc..Im getting built a 1916cc motor built at the moment for my wifes street bug and only running a set of 40mm IDFs with 40mm valves in her motor theres no point running 44-48mm carbies...besides losing airspeed and low down torque..speak to an engine builder I would suggest.
ian.mezz 路
馃槀馃槉馃槀
FROSTY 路
Hey Sides, I have had 40 dell's 32vents and they work fine. I am going to put them on to my 1600 street beetle and i'm wanting a new set for the drag bug.
1776cc, engle130 cam. I want to get the biggest carb possible incase i upgrade in the future. Probabliy best to go with 44idf.
Thansk
Jason
donn 路
You won't get a bigger carb than the one in Mr. Mezz's 2nd pic above, about 600mm high I'd guestimate. 馃槀
ian.mezz 路
donn wrote:You won't get a bigger carb than the one in Mr. Mezz's 2nd pic above, about 600mm high I'd guestimate. 馃槀
they are 48s
zayus 路
they are 48s [/quote]
Just like the the Marlboro Holden Dealer Team used, back in 1979!
