12 point CV bolt tool?
https://forums.aussieveedubbers.com/threads/93922/12-point-cv-bolt-tool
Vanders ·
Where can I buy a tool to undo the 12 point CV joint bolts used with a Type 3. The local tool and fastener suppliers have nothin.
Aussie Dubbin ·
You will find this a bugger. I would see your local shop and see if you could borrow just the tool... or Maybe ebay you might be successful.
dragsters for life ·
damn i been looking for one of those aswell
vwo60 ·
any tool place will have the twelve point torque bits
barls ·
george had them on the shelf last time i was there
They can also be called
Triple Square
or XZN
They are a very strong type of fastener that is able to be torqued up very high. I would get hold of a driver bit, and slip a spanner over it. Keep it with the car. I would definitely keep the XZN drive for this application.
Vanders wrote:Where can I buy a tool to undo the 12 point CV joint bolts used with a Type 3. The local tool and fastener suppliers have nothin.
I think I bought mine from auto one off the shelf..
Vanders ·
Repco can get them in the end. It took some searching thruogh parts catalogues though.
VVDS have them in stock
Lucky Phil ·
Got mine from CIP1 in my last order.
cam070 ·
I got one from Meyers Manx http://www.meyersmanx.com.au a few weeks back
cheers for all the tip offs, im gonna go get one now
Yes, I got mine from Auto One ...
Kinchrome brand size 8mm
i was told it was 6mm i needed
beetleboyjeff ·
dragsters for life wrote:
No, mine has 8mm on it (if you can read it on the blurry photo).
RATAFIED ·
mine is sidchrome M8 part#14296
i think i got mine frome supercheap
RATAFIED wrote:mine is sidchrome M8 part#14296
cheers for the pics
empi ·
Eccles, i have 2 they are M8 keys
cam070 ·
I just found this, a whole set on Amazon, http://www.amazon.com/Vim-VIMXZN100-8-Piece-XZN-Set/dp/B000I1Q60O/ref=sr_1_9?ie=UTF8&qid=1322108027&sr=8-9
esevwbits ·
Allen key will get you out of trouble if you aren't at your shop. learnt this a long time back 🙂
chillihilli ·
I bought mine from Just Tools in Clarendon St Melbourne for about $20.
http://www.justtools.com.au/
Also buy yourself a cheap a 6mm allen key for the ones that need extra coaxing. Hammer in the allen key and vice grips on the outside should do it.. Lots of WD40.
And if you go through the above, don't forget you'll need a few spare NEW CV bolts and washers to replace the ones you coaxed out 🤘 Mick Motors or Wolfsburg have em, or you can buy them from most online bolt shops.
cheers Pete
