push rod tubes
https://forums.aussieveedubbers.com/threads/93988/push-rod-tubes
greedy53 路
can you use a spring loaded pushrod tube like the 1600 on a 2 lit or is it a head of bla bla bla and fix 馃ゲ馃槧馃お馃お馃お
Craig Torrens 路
If its a 2lt kombi motor then the tubes can be removed and replaced without the heads coming off馃憤
greedy53 路
cool craig how does the new tube slide in i'm bit dumb when it comes to2 lit although i have had plenty of practis with the rest of the evil things
matberry 路
Type 4 tubes slide in from the tappet cover end with rockers off and pushrods removed. Replacement or seals able to be done without removing heads. 馃憤
greedy53 路
well blow me down thank s to all see i learned something new now what are the lotto numbers for monday and all wll be perfict
