Aussieveedubbers 路 Tech Talk
Fan Speed & engine RPM
https://forums.aussieveedubbers.com/threads/9399/fan-speed-engine-rpm
jakriz 路
I've been thinking about the pro's & cons regarding using a full size pulley on a high revving engine. If a stock motor & fan is designed not to be really revved over say 4500rpm, then once u start revving the engine to 6000rpm up to 7500rpm, does the stock fan become useless, like it is spinning so fast that it creates some type of void of air that doesn't actually get pushed over the heads & cooler?
So if I was to use a power pulley on the track it would actually cool better since the revolutions of the fan would be a little closer to what the stock fan does at 4500rpm , to the power pulley spinning at 6000rpm & higher?
Am I just thinking too hard?
regards
Jak
KruizinKombi 路
That's the theory. Evidently when the revs get too high (don't ask me how high), it causes cavitation and the fan doesn't blow very effectively. This could be detrimental to the point where it is actually cooling less than it would at stock revs, even though your motor is making much more heat.
Power pulleys are designed for exactly that purpose. 馃檪
That said, I've never used one, because I've never built a motor designed to rev to those speeds.
Baja Wes 路
Man whoever starts these rumours is on drugs.
The fan WILL NOT reach a maximum flow.
Air does not cavitate. Cavitation is when a liquid is suddenly accelerated, the change in energy from pressure to velocity causes a reduction in pressure and localised boiling. Air doesn't boil, it's already a gas.
The fan will keep pumping out more and more air the faster you spin it. Eventually it will explode.
The problem is the power used by the fan increases as a cubic power of the fan RPM. So at higher RPM the fan will be sucking so much power the fan belt will simply slip. This will give the apparent effect that the fan has reached it's maximum flow, but it hasn't, it just isn't getting spun any faster cos the belt can't transmit the power required.
Jak, you really should use a power pulley. It will have very little effect on your cooling. The heat transfer to the air is related by the 0.73 power of the engine speed, so the loss of cooling is not as much as the loss of fan speed. If that makes sense.
What fan RPM do people think the fan stalls/cavitates anyway?
vw54 路
good theroy
Jak you would be better of concentrating on getting a good condition welded fan.
The swaging on the blades and such will proberly be getting stretched to there limit, and by welding and stress relieveing a fan, perhaps there will be less chance of it flying apart.
Are you having over heating problems now ??? oil temp obiviously goes up when you push it but to what temp on yr gauge ???
Baja Wes 路
I used to run a power pulley on my 1915 in winter, and a normal pulley in summer because I used to offroad at very low RPM alot.
If I were you I would try the power pulley. You won't notice much difference in temp, but you should notice a bigger difference in top end HP. It should rev out a little further a little and a little more freely.
Read this if your bored
http://offroadvw.net/tech/wes/fan.html
I got heaps more info than that.
Brad 路
The age old argument. 馃榾
I am not going to repeat all that tech stuff Wes has said, although I could copy and paste it from his theasus thingy. He is actually the only guy I know who bothered to work out the theory behind what went on in those fan housing things with fans.
I did have few thoughts myself a few years back and attempted to "blow" a vw fan up to see what happened. I made up a test rig with an electric motor, and some push bike bits. Anyway I got it up to just under 12000 RPM and the bitch didn't seem to care. I tried to measure air flow from it and although I am positive it was pushing much more at 11000 than 6000 I have no proof as I couldn't get an accurate measure. I was quite suprissed it kept pumping I thought it would do some weird stuff before that.
Anyway then I read Wes's pages and pages of tech dribble and didn't bother trying to calculate the difference cause his was heaps cooler.
I reckon if you are gunna run the engine over 3000 rpm, wack on a power pulley and cut sick. Run a temp guage and you can't go wrong.
If you want more specific advise and reasons just ask Wes, I am sure he will be more than happy to pull out that documnet he put 12mths of his life into...
jakriz 路
The oil temp on the street is amazing low, but on the track I would like to be able to do more than 3-4 laps without having to pull in to let it cool down.
For example, driving to work today for 20 mimutes the oil wouldn't go over 50d, thats without turning the fan on the RX7 cooler on. On the F3 to get to the track it's lucky to get to 80-90d, but after a few laps flat out, especially in summer the dial will go off the guage & thats about 130d. I've just got myself another fan for the cooler today which I will put on for Eastern Creek so that I'll have 2, but I'm starting to think that there may be more to it than just adding more fans & oil coolers. Thought the fan speed may have more to do with it.
The guys overseas are running around 100d for 30 lap races! but they are using the Porsche fan shroud.
regards
Jak
Bizarre 路
Rather than the power pulley - go the other way
I have lost the thread but a while ago on the original SBO site some one posted that a Porsche 356 generator pulley fits a VW generator. These are a smaller diameter that stock VW.
This will spin faster and push more air
"IF" you are REALLY interested follow ol' Jake on STF
He is doing a series of tests with some radial fan and his massIVeDTM shrould
I think you would get something out of it Jak - have a look
Baja Wes 路
Trying to run the fan faster will not to anything but make the fan belt slip earlier.
Jak is running high rpm, where the fan sucks so much HP that the fan belt can't turn it any faster. So trying to changing the pulley ratio's to turn the faster isn't going to do anything.
The 911 fan pushes a hell of a lot more air than the beetle fan.
If I were you Jak, I would look at your jetting. From what you at describing your carbs are leaning out at higher rpm making it run hotter than normal. Jet it richer and it will run cooler. Have you had it dyno tuned and had the air/fuel ratio plotted?
jakriz 路
I have had it dynoed Wes, & u are dead right, it was rich down low & lean up top. Since then I have installed a CB Performance update kit in my 45mm Dellortoes which gives it a horizonatal dishcharge tubes & different jetting to suit. I have yet to put it back on the dyno though. Maybe I should purchase an air/fuel ratio guage?
regards
Jak
Grey 57 路
May sound obvious but are you running deck stand offs Jak. With the higher revs the fans is moving much more cu.ft. of air. Possible that the standard air slots in the back of a beetle only allow so much air thru before they become restrictive.
Baja Wes 路
good point grey. Gene Berg actually done a test with a dog house fan fitted to an early bug with no decklid vents, and measured a noticeable pressure drop in the engine bay. The low pressure vw fan would be quite sensitive to this. Gene recommended using a later vented deck lid with the dog house shroud.
See if it's still lean up top Jak. It could be doing your engine real damage if it is. Better to be too rich than too lean in racing conditions.
68AutoBug 路
Very good answers to the posts Baja Wes... very interesting topic.... I enjoyed reading them.... and I'm very glad that the Fan on MY 68autobug isn't about to implode or explode etc...
Text
I always liked the idea of a slow revving air cooled , horizontally opposed 4 cylinder engine.... :bounce:bounce:bounce:bounce
jakriz 路
I don't need decklid standoffs as I run an Aero wing. Besides, I've used the stand offs before & for really high speeds u can't beat the wing. Despite what people say about the looks.
regards
Jak
Brad 路
Hey, are you still running a dog house and an oil cooler ? Have you though of using a type 4 cooler in teh T1 shroud. I have found it is good for a few degrees. Also put on some cool tins or type 3 under cylinder trays. These will help you use the air you are pushing over the cylinder heads better.
It is one thing to move more air, it is another thing to actually use more. If it doesn't get enough time to take the heat with it.
The guys with the porsche fans are a completly different ball game. That of course would be the next option. Slap and 11 blade on it and have no more heat problem.
I have managed to keep my Manx at 80 degrees all the time now, even when in soft sand at 4000 rpm and above for long periods. Took some stuffing around so it didn't run cool on the street as well.
jakriz 路
I did the type 4 cooler in the type 1 shroud years ago & it was a waste of my time, absolutely no difference wether on the street or track.
I am running the type 3 cool tin under the barrels & I've also run without it & it too was no difference, but I'm still using it.
regards
Jak
Stanley 路
My 2c worth. I was in the hydraulic ind. for a few years. Air to oil, oil coolers are one thing standard on all mobile equipment. sizing these is an art as bigger is not always better. Cavitation can happen with fluids and gases eg jet engines can cavitate. Cavitation is basically a vacuum where the inlet is restricated ie you get implosion in fluids and a vacuum with gasses
With regards to a vw fan etc you get to the point where the heads and barrels become a restrication and regardless how fast you turn the fan you can't jam anymore air through the tin ware.
When this happens you get an increase in pressure on the outlet side of the fan which ultimately robs the engine of HP at high RPM this air can quite often be turbulent and not be efficient.This is why flexible blades were designed on early race cars blades flattened out when the airflow through the radiator was at its max due to movement of the car. If someone could develop one of these for a vw you could pick up some HP at or near full noise.
So long as you don't get a neg pressure in your engine bay your laughing:bounce
vw54 路
Jak
I would rather be Rick at revs than lean... Its got to be do some harm to your engine... perhaps a bit more fiddling on the dyno with jets.
It will probally be impossible to get it right for both conditions but rich at revs would be better... than blowing and overheating yr engine.
Perhaps a different heat range plug could be the answer for both types of driving ??
Grey 57 路
What about oil flow thu the cooler. If the motor is running at higher RPM on the track then everything is moving thru the engine at twice the speed of you travelling down the M2. Is it possible that the oil flow thru the cooler is too fast for proper oil cooling to occur on the track. ?
jakriz 路
I agree Dave , I'm sure it's no good for the engine despte the short amount of laps that it's on full song.
I've added another fan on the RX7 cooler today, they are from the front of a Bay window Kombi, they pump out heaps of air. I'm also going to make a shroud out of some flashing as U can only feel a little air coming through the cooler whereas the rest is just bouncing off in abundance. I think that it will cool more efficiantly with the air forced through the cooler. I've also wrapped my oil lines with heat wrap since they are so close to the header which gives off major heat.
I'm going back to the dyno in the next couple of weeks.
regards
Jak
Baja Wes 路
Hey Jak, have you thought about putting a real thermo fan on the cooler? A proper thermo with proper shrouding will do a lot more than a kombi fan. Definitely find some bigger jets too.
Kafer, cavitation only occur's in liquids. It is not vacuum bubbles, it is vapour bubbles (ie boiling of the liquid into it's vapour state). The boiling occurs at ambient temperatures due to a large drop in pressure, such that the pressure goes below the liquids vapour pressure, and it vapourizes. This damages pump impellers as the bubbles form and collapse rather violently taking some of the impellor with it.
Anyone who uses caviation with a gas is not using the term properly. Jet engines are a different problem. A form of choked flow. It's to do with a converging-diverging nozzle being required to accelerate a fluid past it's sonic velocity.
If you do the calc's for a VW fan you'll see the velocity required for choked flow is extremely high and the VW fan will never get there. That is why I said it will explode before it meets a maximum flow. Remember most Jet engines are very strong with titanium blades and the VW fan is a crap piece of pressed steel.
1303Steve 路
Ask Keith Hausler about exploding fans, he has minced a few.
Jak I think you need to get the cooler in the airstream, maybe the scoop will work but you may have to cut up the Kamie.
1302Steve
KruizinKombi 路
Hmmm, too high tech for me. :o I'll take Wes's word for it, because I know that he does his homework. :thumb
I reckon the 'proper' thermo-fan is a good idea, and the shroud is a necessity too.
What about a water spray onto the oil cooler, controlled by a thermostat? Or even water injection into the inlet manifold? 馃檪
jakriz 路
I don't think that the 'Thermo -fan is the answer. CT has one & his oil temp goes off the guage way before mine.
I took it for a drive today & after giving it a blast I finally got the oil temp up to 80d & when I turned both of the fans on, the oil temp quickly dropped back to 50d & that was cruising at the speed limit. It will be interesting to see what it does on the track, & with the shrouding.
I've played around with the cooler up fron under the front bumper, but the RX7 cooler stands out like dogs balls, its very visible & suceptable to damage, at least where it is it's safe.
I've also thought about the water spray as well. I was going to put a electric windscreen washer bottle behind the back seat & just have the nossle sticking through the parcle tray. MY only concerns are putting water on the track? Would it go everywhere? or would it just dissolve & would it really cool? Alot of guys use water spray on their intercoolers so there should be no reason it would'nt work on an oil cooler?
Dunno?
regards
Jak
PS thanks to everyone for their input!
helbus 路
But wouldn't that also mean it flows through the motor too quick to get as hot, or that it would go through the cooler twice as often?
[Edited on 17-8-2003 by Helbus]
Grey 57 路
Dunno Pete, I think I'm like Kol and well outta my depth.
Water spray sounds like a good one tho. Engine parts give up heat turning water into steam.
[Edited on 17-8-2003 by Grey 57]
helbus 路
I had some probs with overheating in my EH Holden, and as it runs an electric water pump, some people were quick to say it was because the water was flowing too fast through the radiator to cool down.
I thought about it and came to the conclusion that it would also mean that the water spent less time in the motor getting hot, but it would do it about twice as often.
Fixed it anyway. Got an aluminium radiator with huge core made up and a monster 16" thermo fan.
Radiator guy said it is enough gear to keep a 350 Chev cool.
Anyway back to VW's for me.
Baja Wes 路
The oil flowing too fast will not cause a problem. The faster a fluid flows through something the better it transfers heat to the walls of what it is flowing through. That's the simple version 馃榾
Sure you will get a smaller temperature drop at higher oil flows, but your right about it also rising a smaller amount through the engine. You have to look at the total heat transfered though. Because the convective heat transfer coefficient is better at higher oil flows, the total amount of heat removed will also be higher.
Tell us how your various mods go Jak. I'd be interested to see how the dyno tuning goes.
fullnoise 路
With regards to Jak's comment about my thermo fan not really working that well it's hard to judge due to difference circumstances.
Jak's engine has the benefit of less compression and a big wing to feed cool air to the engine bay.
My 1916 runs about 10:1 compression with no stock oil cooler. My only oil cooling is a 96 plate messa cooler with a Davis Craig thermo fan mounted snuggly above the gearbox.
My engine seems to run a lot cooler than other Stan Pobjoy engines that only use the stock oil cooler.
The other pobjoy engines I'm talking about run lid lifters or hoodjaks. Neither of which I will run for aesthic reasons.
I imagine it would be hard to fit a thermo fan to Jaks RX7 oil cooler since they are long and rectangular.
My thermo fan is operated by a toggle switch. I find that temps will keep climbing if I don't turn the switch on. The thermo fan stops the temps climbing rather than dropping the temperature.
I find that my engine will sit on 80 - 90 degrees around town depending on the weather. It will sit on 90 - 110 on the freeway also depending on the weather. When pushed at the track I don't let it go above 120. I feel that this is all pretty safe. Once the engine gets to 120 it will cool down to 100 alot quicker than it will cool down to a lower temperature.
If cruising on the freeway and the engine has been sitting at 95 degrees for a while if I give it a blast and bring the temps up then resume my original cruising speed the engine temps will not go back to 95 but more likely 100. If I was to rest the engine by coasting down a long hill the temps would drop to 95 and would stay at that temperature when I resume my cruising speed.
I hope this blurb helps somebody.
CYA, CT
jakriz 路
C'mon CT, I didn't say it doesn't work, I said I didn't think it was the answer since yours runs hotter than mine, thats all dude:thumb
Jak
Peter Leonard 路
my old, base 1916 Pobjoy motor never runs that hot, but I have a heap more ventilation in my engine lid than CT. I do run hoodjacks on really hot days, or on freeway missions, but only because i like to stay below 110 degrees. sans hoodjacks I get 120 degrees blasting up long hills, but air is free... I like to feed mine as much as it's blessed little aircooled heart can take. interesting to find that the fan belt starts to slip at high revs due to increased power demands on the pulley/belt with respect to the fan smashing at the air, mebbe it's possible to get some kind of belt drive system? air can be quite solid when you push it hard; check out the friction generated when you're coming back from the moon one day. re-entry is a bitch. 馃榾
OR stick your hand out the window at 110k's, it's way cheaper as an experiment, and you can do cool wavy flappy motions :thumb
interesting to find out what airspeed/pressure it takes to start pushing the limits of the fanbelt's grip. or maybe thats just me. love to have a squiz at wes's thesis.
one more thing: the oil cooler isn't the only thing that cools the engine, the better your tinware is sealed, the better the stock cooling system can direct the air around the rest of the motor. another possibility is the addition of fins/heatsinks wherever you can make them fit in the airflow. i guess.
good topic. 馃榾
keep on ramblin....
lugnuts 路
Hey CT why no stock oilcooler,shouldnt you run both ( i know buggerall thats why im askin).馃槈
fullnoise 路
I used to have a Berg pressure relief oil pump cover pumping the oil to a filter and then to a thermostat and then to an oil cooler and back to the engine where it went to the standard oil pressure reliefs and stock oil cooler.
Stan Pobjoy said that was all too complicated and may cause oil surge. Stan suggested to run some short oil lines from where the stock cooler mounts and to keep it simple. So that's what i"ve done.
I modified my fan housing so no air goes to where the dog house cooler used to be and no air goes to the heater ducts. With all the air dedicated to cooling the heads and barrels this may help too.
I might try an original 36 horse shroud with a 1500 fan to see if there is any temperature difference. I think the smaller fan housing would help the carbs breathe. I think my air cleaners seem quite boxed in between the fan housing and the cars body work. The extra room may also give me the opportunity to build some cold air boxes. That way I can feed the carbs with cold air from under the car and stop the carbs robbing the fan of cooling air.
If it works I'll tell you.
CYA, CT
Craig Torrens 路
Jak, have you changed something with your setup, I thought your temps on the track rarely went over 120deg ?
CT, have you thought about running the stock cooler, with the external cooler oil lines running off an adapter plate mounted between the case and cooler ?
I have seen them at Vintage VW, not too sure if they work, just an idea :thumb
I run a 36HP (aftermarket) "doghouse" shroud, you will love the extra room in the engine bay !
I think Wes has studied/researched the internal fins of the various fanhousings,will the standard 36HP shroud have enough fins to direct the air flow?
lugnuts 路
Thanks :thumb
Baja Wes 路
actually Brad did the fan shroud destruction 馃榾
http://offroadvw.net/tech/brad/fanshroudtech.htm
Just get the last dog house shroud, and cut the sides off. That will make it thin. Cutting the sides off will not effect the air flow. As you can see in the pics, the sides are just dead ends anyway. On one of my old engines I cut the sides off, and also cut another little section near the top that didn't do anything. It made a cool funky shaped shroud.
modulus 路
Jak,
Autospeed had a very interesting article about water cooling spray on an air-air turbo intercooler, viz:
http://www.autospeed.com.sg/cms/article.html?&A=0527
This is IMHO, one of the better thought through and tested performance cooling articles and much of it is directly applicable to oil cooling.
HTH
Brad 路
Craig Torrens wrote:I run a 36HP (aftermarket) "doghouse" shroud, you will love the extra room in the engine bay !
In short NO, teh stock 36HP shroud need the stock oil cooler to invert the air and remove the void that is created by the removal of fins to allow the fitment of the cooler in the first place. Follow the link Wes posted for more details.
I think you need to get your mixture correct before you worry about the other stuff. You can cool your oil all you want if she is lean you will stuff it anyway.
jakriz 路
Thanks for that Link Peter, most appreciated, & thanks Wes for the pic of the fan housing, I'm sure that many like myself have never seen that before.
I found a link on the Shop Talk forums regarding the air flow from the porsche fan on VW motors,basically the motor can't use all the air & runs too hot, the solution was to make 2 holes in the back of the fan housing to let some of the air out.
I've included the link.
regards
Jak
http://www.shoptalkforums.com/viewtopic.php?t=53582
fullnoise 路
Hmmmm, it was interesting to see the cut-away of the dog house fan shroud. After seeing that I'll just modify another dog house shroud instead of going for the 36 hp option. I've already modified my housing in a similar fashion. However it's copped a few two many modifications over the years.
What are the aftermarket shrouds like. I've heard they're crap but has anyone ever done a cut-away as per above?
CYA, CT
Craig Torrens 路
my aftermarket shroud is of good quality, there seems to be the same number of fins as a standard doghouse, and the temp runs the same as the original. I bought it years ago at a swap meet. I have seen some crap ones where the fins have only 1 spot weld per fin !
Looks easier and cheaper to customise a stock 1600 shroud.
VWCOOL 路
What I think he meant was, his fan housing is a 36hp 'shaped' narrow unit, with no heater ducts, to provide extra space for the carbies, but all the internals of a 1600 including the fitment of a doghouse (external breathing) oil cooler
Brad 路
Ok there are several aftermarket shrouds availible. Most of the ones which come fitted with a dog house cooler have internal ducting which is similiar to the one I cut up above.
The aftermarket shrouds which are not fitted with a dog house generally suck in terms of internal ducting.
You best option is to cut down a factory dog house shroud and use its fan as well. If you cut them down as seen in the above picture you can take quite a bit off them.
I have a shroud I cut open and then removed evry mm I could get out of it. I am now going to put a perspex front on it after paint the internals with fluro paint and a inserting one of those ricer glow sticks. This way I can easily explain how it works to people and dispell a lot of the miss information people have gained in relation to it being a good idea to pull out the internal oil coolers to assist air flow in the pre dog house shrouds.
vw59 路
Hi,
I very rarely post a reply but I thought I'd ad a bit about what I've learned.
I found that when modifying a motor, ie: stroking the motor it changes the width of the motor as we use shorter barrels etc, so the tinware doesn't always fit as well as it did standard. It may look unsightly but I use black silastic to fill all small gaps in the tinware between the shroud and head tinware, any small gap is allowing cold air to escape which is not being pushed over the cyclinder heads & cooler.
Gas can indeed cavitate, I am a Hydrographer by trade so see it happen. When a gas say for instance enters a valve which has not been sized correctly (ideally a valve should operate at about 70% of it's total rangeability which is maximum flow/mimium flow. If a valve is incorrectly sized the gas cools to a liquid (large pressure drop across the valve which ideally should operate with 1psi but often doesn't due to flow characteristic problems) it cools, then on the exit of the valve it speeds up again turning back into a gas. This is called flashpoint! Its what makes a gas pipe very noisy around a restrictive valve. Ideally a valve should not cause gas to cavitate as it should be ranged using the turndown equation which is maximum normal operating range/ minimum operating range.
I have heard of several fan exploding but only because the person had solid mounted the gearbox so unfortunately the road car when driven on the street has to absorb every bump and vibration which is transfered to the fan from the solid mounts. Rubber is installed to absorb vibrations on a road car from our not so great roads!
When changing the compression of a motor the fan is designed to supply a certain CFM per minute. When we up the compression, I think we also need to change the 4th gear as the motor is running hotter in theory but the fan is still turning at the same rate if ideally cruised in 4th down the highway. A lower 4th will make the rpm increase so the fan will operate faster but the motor will also be working just that little bit harder.
Cheers Leigh
馃檪馃檪馃檪:bounce
Baja Wes 路
Hi Leigh, it was good to meet and chat with your at Valla.
vw59 wrote:Gas can indeed cavitate, .... ....gas cools to a liquid....
Gas does not cavitate. Read any good encyclopedia or dictionary definition of the word and you will see it doesn't apply to gas. What you are describing is the gas condensing, and then the liquid form cavitating or more correctly flashing off. And we don't need to worry about this problem on the VW engine cos the air sure won't cool to liquid oxygen as it goes through the fan.
But the main reason I posted is the theory of changing the engine speed on the highway up or down to change the cooling. I've seen US vw mags publish that the VW engine is at it's most thermally efficient at 3100-3300rpm, so that's what rev's it should do on the highway.
My practical experience was my baja. When I had an L bug gearbox;
3rd gear at 100kph was doing 3200rpm
4th gear at 100kph was doing 2400rpm.
I can tell you if I used 4th at 100kph it ran a lot cooler and used less fuel than 3rd. You don't have to spin the vw fan that hard to make it work. The extra fuel you use spinning everything that much faster counter-acts the extra cooling from the fan. Or at least it did on my 1915cc Baja. 馃檪
vw59 路
Hi Wes,
Thanks, I too enjoyed meeting you. It was great to see such a greatly engineered and well thoughtout project with all the documentation to prove it theory and design principals. No your right, sorry I meant to type water not gas. It cavitates as it turns from water back to a gas, my mistake. Thanks for correcting me on this one! But your correct in saying also that air cannot cavitate.
Looking forward to seeing you Queenslanders at the next Valla.
Cheers Leigh
馃檪:bounce
