Body Removal - HELP!
https://forums.aussieveedubbers.com/threads/93992/body-removal-help
cam070 ·
I am attempting to remove the body from the pan of my standard beetle. all electricals etc + steering column have been removed or disonnected. I have so far removed:
- 2 x bolts on top of the beam
- 4 x 17mm bolts (2 each side) that go into the framehead
- 18 bolts (9 each side) that run under each side
- 4 bolts that run across under the back seat
- 2 bolts near the rear shocks
Are there any others?
And should the body now lift off as it still seems fairly stuck to the pan.
Any help advice eagerly accepted as I am supposed to be loading the bosy onto a trailer tomorrow to go to Advanced Soda Blasing on Saturday.
Cam
Anthiron ·
Brake resovoir line to the master cylinder
Electrical wires through the fire wall from starter motor
fuel line through the fire wall
wires to master cylinder brake switch
disconnect wireing from loom to engine etc
cam070 ·
Anthiron wrote:Brake resovoir line to the master cylinder
Yep all that stuff has been disconnected or removed. is theer anything else I have missed or is it just that 35 years of mating has resulting in some bonding?
cam070 ·
I just found this article that is for a super, but from what I can gather is reasonably similar to a standard, but still doesn't explain why my body and pan doen't want to part ways.
http://www.vwtrendsweb.com/tech/0406vwt_1971_beetle_super_project_part_11/index.html
It's just the sealant holding it together.
cam070 ·
matberry wrote:It's just the sealant holding it together.
I was afraid of something like that.
If I put the bumper brackets on and jack up the car using them, do you think it will separate?
cam070 ·
Also found another guide which is a good reference:
http://www.superbeetles.com/Tech_talk/jun.htm
vwjon ·
steering column?
cam070 wrote:If I put the bumper brackets on and jack up the car using them, do you think it will separate?
Most likely, although worst case is while under load with your jack on the rear bumper brackets, a pry bar on the shock tower to body against the strong steel mount should do the trick.
cam070 ·
vwjon wrote:steering column?
Yep that's out too.
cam070 ·
Ok Matt you were right. We jacked up the car using the rear bumper brackets and had someone stand on the rear wheels.
Ended up being less drama and swearing than I expected.
Off to the soda blaster tomorrow!
