This was how my trop home from Run to the sun Goldie went.
Thanks To all Who helped me out. Cheers
YIKES
don't You check Your ball joints??
usually get loose long before they collapse
lucky no damage done to anything...
telf ·
Yah check them every so often. But no wear. The bottom 1 sheared off and then the top popped out. All ok not really any damage to the car. Cant say the same about the road.
Burrelli ·
That is scary!
Does your car have the full bump stop?
telf ·
no i chopped them off.
Matty v ·
Lucky you wernt going any faster!
telf ·
I was just exiting a double round about and think that the turn made it happen. Don't think it would have happened on the straight, but May be wrong. New ball joints arrive tomorrow so back on the road by wed night. Its a daily driver so it does get hammered abit.
telf ·
This is how it looked 20 mins before.
vlad01 ·
Holy shit! you didn't have aftermarket ball joints did you?
Or perhaps rust pitting to the ball joint pins?
telf ·
No they were German. Haven't had a real good look yet.
Burrelli ·
Without the bump stop there is nothing to stop the ball joint going to an angle it was not designed to. I'd say If you have a look at the ball joint you will see where it had reached its limit of travel and the inner ball part had been hitting on the outer. I've seen that in type1's as well.
Matty v ·
What height or settings are you running?looking at lowering my fastie?
telf ·
Its 3 outer splines at the front and 2 outer at the back.
Its been that low for about 3 years with no problems. so ill just make sure i replace them abit more often. But hopefully in the not to distant future it'll have a type 1 narrowed beam.
telf ·
All sorted tonight so back on the road. Now to terrorise some speed humps.
Matty v ·
Sweet good to hear your back on the road. Did you lower the car yourself?
telf ·
Yah me and my mate did it about 4 years ago. The type 3 is the easiest to lower out of the VW family.
