Hey all
this is very cool!
but wanted to know if it's for real
the only thing i can see thats wrong is lube and spark
http://wimp.com/tiniestengine/
RISKY4LIFE 路
https://forums.aussieveedubbers.com/threads/94094/worlds-smallest-v12
RISKY4LIFE 路
donn 路
LUFTMEISTER 路
donn 路
vlad01 路
helbus 路
Ben386 路
reub 路
RISKY4LIFE 路
ahhh so it runs on compressed air that make sensevlad01 wrote:When I saw that the cam gears were 1:1 I knew it couldn't be a real engine, then I saw it was one of those air engine that run on compressed air.
i dont see it blowing any smokehelbus wrote:1:1 cam. Maybe it runs two stroke? Like a model airplane engine, using compression ignition like a diesel. I remember an engine in a model plane my brother had that ran on something like methanol, and it had no ignition or lube. You just wound the prop backwards on a spring, and it unwound and started and ran on compression ignition. It did have a glow plug thing you pre heated with a 9V battery.
hahaha when he retires ?reub wrote:Ok.. so when is Dave Butler going to build a scale pauter engine??
vlad01 路
Nope, its an air engine. these are very common for very small scale model engines. Simply for display.helbus wrote:1:1 cam. Maybe it runs two stroke? Like a model airplane engine, using compression ignition like a diesel. I remember an engine in a model plane my brother had that ran on something like methanol, and it had no ignition or lube. You just wound the prop backwards on a spring, and it unwound and started and ran on compression ignition. It did have a glow plug thing you pre heated with a 9V battery.
