Wanter Early Oval Bonnet hinge Bolts and washers
https://forums.aussieveedubbers.com/threads/94111/wanter-early-oval-bonnet-hinge-bolts-and-washers
Turbo54 ·
Hi All,
I have seemed to loose my set of bonnet hinge bolts and washers for my oval. These have quite a flat head and a little step down before the shaft and thread starts. The step down locates it in the hinge and stops sideways movement.
If anyone has a couple I could buy it would be great. By 54 is needing a bonnet.
T54
HappyDaze ·
You only need 2 stepped bolts - 1 each end of the bonnet stay, the others are normal bolts.
There are 2 more, fixing the hinges to the body.
Turbo54 ·
Thanks Happy Daze, yes I need the 2 to fix the hinges to the body.
I have all the other bonnet and bonnet stay bolts.
T54
Dasdubber ·
G'day Heath,
We have them in stock if you get stuck and can't find second handies (unfortunately don't have the washers though):
http://dasrestoparts.com.au/hood-stay-bolt-54-61-bug-hood-hinge-to-cowl-through-79-bug-engine-lid-prop-through-mid-64-bus.html
Cheers mate
Al
