can anyone tell me how i would go about taking a flywheel off a 1600 and bolting it onto a 1500?
wat toold needed? torque wrench etc ???
any spectialist tools needed?
anything i should know?
adz
type82e ·
you'll need a flywheel lock or a piece of angle iron with two holes in it to bolt to 2 of the pressure plate bolts to hold the flywheel while you undo the big 36mm nut
a 36mm socket to undo the nut and a long extension for extra leverage as the nut is ussually very tight
while the flywheels off change the oil seal at the back of the engine
marcel
geodon ·
Muir's book goes thru this using very little w/shop manual verbage esp re torquing the flywheel down again. If you change the seal make sure it goes back in nice & straight. I think (?) Muir suggests using a big washer & the flywheel nut to seat it properly.
