I have done a tidy up of the shed and found a few parts that I will never use on my car.
I don't have pictures of the cam or clutch, but they are basically new and in their original boxes, un-opened.
1 x Web 86B turbo grind camshaft (Same as FK8) 300 degrees advertise duration. 260 at 0.050", 0.575" lift at the valve with 1.5:1 rockers. The cam has been clearenced for a stroker crankshaft, and also has had the Aircooled.net hardweld option. Cost over $300, and its yours for $200.
1 x Kenedy Stage 3 pressure plate. New, un-used and in original packaging. I was going to use this with a 4 puck, but went with a twin plate instead.
1 x set of QSC 94mm Nikasil/aluminium cylinders. The quality is very good, but they are not thick enough for a high power turbo application. Will suit a high compression stroker motor nicely, and are a lot cheaper than the LN engineering cylinders. Cost me over $800. Yours for $500.
Call or txt me on 0434147478, or send me a pm.
Ian
2443TT ·
