17 inch wheels
https://forums.aussieveedubbers.com/threads/94257/17-inch-wheels
jack schoot ·
Would anybody know the modifications needed to fit a set of 17inch escras to a 61 beetle.
thanks
I don't think that you can buy them in your wide 5 stud pattern. So you would need to fit a front disc brake conversion and 1500/super bug rear drums, in the correct bolt pattern.
I'm not sure what offset you would need.
vwjon ·
you could buy blank drums and have them drilled to suit the stud pattern of the rims, legal and a cheaper alternative.
kombibob ·
a narrowed beam would help but with the correct tyre size they should bolt straight on
empi ·
Escras only come in 205mmpcd so they will bolt up to the car, if you lower the car you will need to do a narrowed beam and careful choice of tyres. Here is a photo od a car i helped build for a mate.
empi ·
nuvva
jack schoot ·
excellent , thanks for the advice guys
JS
Pumba ·
Empi is that beem 2 inches ???
cheers shane.
vwo60 ·
I have 17" wheels on my early car, if you narrow the beam how do you turn around a corner, the smallest tyre is a 205 section, that is what i run, it just clears the front panels behind the wheels on lock and i run 2" over size guards.
empi ·
I run a 185 35 17 tyre on mine.
vwo60 ·
Are they a recommended fitting on a 7" rim.
empi ·
No idea, they fit fine, and didnt have any issue getting them fitted ... 185mm = 7.283inches ...... thats it im going for the 165/35/17 option !!!!i cant have tyres that are legal on my car!!!!😂
