Engle 130 cam card
https://forums.aussieveedubbers.com/threads/94361/engle-130-cam-card
deadkombi ·
Does someone have the cam card details for the engle 130. Intake open, close etc. Greatly appreciated.
dangerous ·
267 degrees at .050" 108 lobe centre.
This means 28/59 on the inlet and 64/23exhaust,
which is advanced 2.5 degrees as per engles recommendations.
Mine always lifted .460 at the valve with stock rockers.
humpty ·
What are you up to P?.... Has the rebuild begun? 😁
cnfabo ·
yeah humpty the case should be buttoned up already...
deadkombi ·
Cheers Dave thanks a lot. The problem was that the straight cut cam gear had 2 dots instead of one. Appreciate your help. Problem solvered.
humpty ·
Race in the new year? 👍
dragvw2180 ·
Here is a link to another web site, topic is cam cards and there are alot of them posted including a Engle 130, hope it helps, Mike McCarthy
http://cal-look.no/lounge/index.php/topic,974.0.html
specs 27/60 int 63/24 exh
