Just wondering if there is an after market heating/fan equivalent to the heater boxes found in bugs? I've got an engine without heater boxes and still want to heat the car, and also defrost the windscreen.
Jimmy
pishtols ·
hey, how u doing jimmy...
ill start off by letting u know im no expert, ive only been into my beetles a couple of months, but was looking for the same thing. Pretty much a 12volt heater element...(im assuming u have a 12 volt....) that u can hook up to the existing fan....
i have looked everywhere...(or it feels that way) in melbourne... not much there.. only thig i did find is a 12 V aftermarket heater with a fan on it. If ur in melbourne, i found it at a place called East Coast Auto spares in bentleigh... (03) 9570-6188 It would heat up your cabin, or so the guy said it should, but as far as window demister etc..... i find it hard to believe.... they went for about $60-$70....
ok, hope that helped.....
Pishtols
type82e ·
It might be cheaper and easier to just put the heater boxes back on the motor you should be able to pick up some second hand or new theyre a bit pricey ($150? each):thumb
KruizinKombi ·
I'd be putting the heater boxes on. There's absolutely nothing wrong with the stock heating system. :thumb
70AutoStik ·
Or, move up here, you won't need a heater... On a more serious note, there used to be electric heaters advertised, but they went the way of the dodo - I supect because of the amount of current they drew (40-60A.) The ones being advertised these days use hot air off a remote oil cooler, maybe you can adapt that idea.
I imagine you removed the heater boxes because you have an oversize exhaust system to match ported heads, in which case your third option is oversize heater boxes from Gene Berg - but they'll cost you, big time. If you could afford to build an engine that needs a 1.5" exhaust system, I guess you can afford them too.
jimmy ·
Yep, the heater boxes were removed before I bought the vehicle. The guy who built the engine put a serious exhaust on it.
70AutoStik ·
Serious can mean a number of things - is it stock diameter (1&3/8") or larger. If it is larger and the heads aren't ported, you'll get more power (throughout the range) out of a stock size system with heater boxes.
Quickbug ·
More info??
I have stock heater boxes on my 1916cc was think of ripping em off but winter would be a bitch - and gotta drive every day...
70AutoStik ·
They don't list the heater boxes alone in their latest price list; but a complete system will come to about $1500 landed for 1&1/2" or $2000 for 1&5/8" You could stay up late and call them - they're pretty helpful.
