Aussieveedubbers 路 Members Rides
TCS_58 bug build
https://forums.aussieveedubbers.com/threads/94489/tcs-58-bug-build
TCS_58 路
Hey guys, very new to the forum and glad to be here. I just bought my first beetle and I have to decided to rebuild most of it. It's a 58, I have no idea what kind of parts has been used on it but it looked the part and from what I could tell, was a good buy. Plans are a 5 speed box of some sort (porshe or other) or a 4 speed bus box that can handle the power, which hopefully will be around the 300HP mark.
Probably going the IRS route too, and last of all, a bridge ported 13B, hopefully a 6 port, NA. Like i said, Im very new and the search button is getting a work out but should you have any links or info that would help me along, I'd really appreciate the input as the build time is limited to 10 months.
Chees, Brett
TCS_58 路
Guards and some old school dish 馃槑
Camo 路
Hi Brett and welcome aboard.
This is a site that may help you a bit - http://frost.bbboy.net/vwengineconversions
Where are you in Oz as others near by may be able to help out of tell you of business that can help.
Your car looks good, I like the all black and how wide are those rear wheels 馃榿馃榿馃榿
Kev
ian.mezz 路
http://bb.bbboy.net/vwengineconversions
TCS_58 路
Cheers lads but I'm already onto that one! 馃憤 I'd love some info on the types of boxes I can slot in my 58, thats the biggest decider in what goes in the car pretty much. I've read that a bus box can fit with a conversion kit of sorts but the figures I've heard are around the 7k mark.. hardly seems worth it unless you're going all out.
ian.mezz 路
http://forums.aussieveedubbers.com/viewtopic.php?tid=82094&page=1
LIFE IN THE LOW LANE 路
Talk to 20Bkombi about rotaries in vw's. He will tell you how much it's going to cost you.....
TCS_58 路
Well I thought I'd give everyone an update... Spoke to the builder I've chosen for the engine side of things and we have settled on a S6 turbo motor. We'll be modifying the motor a bit as we're taking the turbo out of the equation and running higher compression rotors, probably out of an RX8. Will be a full rebuild and balance job with a full bridgeport running a microtech ECU with injection. It will be built to run on 98 octane and hopefully with a decent flowing exhaust will be pushing 230-280HP at the wheels.
Todd from Subaru gears will be building the box which will be one on his excellent hybrid turbo boxes, I honestly can't thank Todd enough for his help with this side of things. Definately a top notch guy and service, highly recommended to all those wanting modern drivetrain equipment in a classic VW!
I'm seriously considering keeping the body just the way it is but with the rear guards pumped out a little more as there will be some serious rubber at the back. I just can't decide on whether to lower it like all hell and keep it that way or to run airbags... I've been told many times NOT to run airbags on a performance car as it does you no favours, what do you guys think..?
