voltage regulator.
https://forums.aussieveedubbers.com/threads/94555/voltage-regulator
Super1302 ·
i have taken the voltage regulator out of my alternator after i found out it was not charging my battery and causing all of my ignition issues.
how do you check it now whether it has failed or not.
i put a multimeter across the two wires and got a reading of 24 ohms. it was set to 200k on the meter. any ideas please.
also where do you find replacement ones. cheers.
greedy53 ·
well if it was still together you could have taken it to a sparky and he could have run it up for you usually free service
Super1302 wrote:i have taken the voltage regulator out of my alternator after i found out it was not charging my battery and causing all of my ignition issues.
not sure what You are talking about...
the diodes???'
diodes.... let current go thru one way only...
diodes are usually used to change AC into DC...
is this what We are talking about?
any pics..?
Lucky Phil ·
Just ditch it and buy a new alternator. Not dear at all.
The old one is only about thirty years old.
AA003 ·
9 diodes in an alternator.
If you have an original VW don't throw it out.
^^^ if you have an original get it rebuilt
You can buy the regulator from CB for $30.00 - but shipping is farking rediculous
Ring VW Parts Unlimited and get it through them
They dont list it but it is available
where are ou located>>>
jamiesc ·
put the regulator back on start your car up and disconnect the battery and it should idle but if your car stops its
buggered i had the same problem two weeks ago and a new one i think is $65
jamiesc wrote:put the regulator back on start your car up and disconnect the battery and it should idle but if your car stops its
I don't think He is talking about a seperate voltage regulator
but a built in one , in an alternator....??
Maybe He's talking about a generator voltage regulator...??
anyone know where He is located???
jamiesc ·
donno think it could be perth
Well he was in NSW last time I posted something to him which wasn't that long ago.
Lucky Phil wrote:Just ditch it and buy a new alternator. Not dear at all.
Looked to be an aftermarket one so probably not that old.
Super1302 ·
yep aftermarket. live Nowra
the regulator inside the alternator.
has two wires out of it. alternator wont charge.
how do you check that it is just a v r at fault.
paul.
Super1302 ·
jamiesc, can you tell me where you got your voltage regulator from, and was it for an alternator or a generator. as the vr on an alt is internal.
