With great regret I am selling the love of my life :o(, she has been a labour of love for 3 years being completed in 2010, but now she has to make way for a new project. She needs to go a well deserving home that will give the love and attention I have over the time I have owned her. She has rego till Feb 2012 and RWC can be supplied.
54,000 Miles (87,000Km) from new only completed approx. 2500 Km from rebuild.
Darren : 0415894905
Runaway Bay 4216
Engine
1. BRAND NEW VW CASE BORED 90.5 CLEARANCED AND DRILLED FOR FULL FLOW OIL SYSTEM
2. CB 82mm FORGED COUNTERWEIGHTED CRANKSHAFT, 8 DOWELLED AND BALANCED WITH CB LIGHTWEIGHT FORGED STEEL FLYWHEEL
3. CB HEAVY DUTY FLYWHEEL NUT
4. CB i BEAM CON RODS 5.5 LENGTH BALANCED
5. CB 26MM HEAVY DUTY OIL PUMP
6. WEB 109 CAMSHAFT
7. CB LIGHTWEIGHT CAM FOLLOWERS
8. CB ALLOY CAM GEAR (blueprinted )
9. MAHLE FORGED 90.5 PISTONS
10. STEVE TIMS, Stage 2 Head: 42x 37 valve size; Street port intake; ported chamber; oval exhaust port; 67cc intake runner. Excellent head for off road and street engines 2000cc and larger.
11. STEVE TIMS MATCHED INLET MANIFOLDS TO HIS HEADS.
12. CHROMOLY PUSH RODS
13. SCAT PRO COMP 1.25:1 BOLT UP ROCKER SHAFTS
14. SCAT HIGH LIFT ROCKER COVERS
15. FULL FLOW OIL COOLER SYSTEM WITH REMOTE FILTER AND REMOTE SECONDARY OIL COOLER AND COOLING FAN
16. BRAND NEW WEBER 44IDF’s AND K&N FILTERS
17. ROTARY ELECTRIC FUEL PUMP
18. 1”5/8 VW SPEEDSHOP STAINLESS STEEL HEADERS AND TURBO MUFFLER
19. GENE BERG THROTTLE LINKAGE
20. CSP COMP PUSH ROD TUBES
Transmission
1. FULLY REBUILT SWING AXLE TRANSMISSION TO PRO STREET SPEC BY COG BOX IN THE UK.
2. 4.12 FINAL DRIVE
3. SUPER FIRST GEAR
4. HEAVY DUTY SIDE COVERS
5. RACE AXLES
6. STEEL SELECTOR FORKS 1-2 AND 3-4
7. WELDED 3RD AND 4TH GEAR
8. 0.88 4TH GEAR.
9. CUSH LOCK COMP CLUTCH DISC
10. KENNEDY STAGE 1 PRESSURE PLATE
11. HEAVY DUTY RACE CLUTCH CROSS SHAFT
Suspension
1. RED 9 DESIGN FULL COIL OVER SUSPENSION KIT, FRONT AND REAR
2. 2” NARROWED FRONT BEAM
3. CB PERFORMANCE DROPPED SPINDLES
4. GENE BERG REAR CAMBER COMPENSATOR
5. HEAVY DUTY FRONT ANTI ROLL BAR
6. CSP REAR FRAME BRACE
Brakes
1. FRONT DISC BRAKES
2. STAINLESS BRAIDED FRONT AND REAR BRAKE LINES
Chassis
1. FLOOR PAN STRIPPED BACK TO BARE METAL AND PAINTED
2. UPPER BODY FULLY REBUILT WITH 1966 NEW BODY PANELS
3. ALL NEW BEARINGS AND BUSHES FITTED AND UPGRADED THROUGH OUT
4. FRONT BUCKET SEATS FITTED AND BLUE PLATED
5. WOOD RIM STEERING WHEEL
6. ALPINE, IPOD HEAD UNIT WITH ALPINE HIGH POWER AMP DRIVING ALPINE COMPONENT SPEAKER SET UP FRONT AND 12” SUB IN PORTED BOX BEHIND REAR SEAT.
7. HEATED FRONT AND REAR WINDSCREENS
8. AUTOMETER 5” REV COUNTER
9. AUTOMOETER OIL PRESSURE GUAGE AND OIL TEMP. GUAGE
10. NEW WIRING HARNESS FITTED AT REBUILD
11. HALOGEN HEADLAMPS WITH INTERNAL INDICATORS.
Sorry about the long post 🙂, just trying to pass on as much info as possible on the car LOOKING FOR $15000 ono A BARGAIN FOR THIS SPEC 😊
Rossi46 ·
