brake shoes cleaning?
https://forums.aussieveedubbers.com/threads/94756/brake-shoes-cleaning
grogy ·
hi, is there any way to sucessufuly clean shoes covered in oil. thanks greg
13bwagon ·
mmm the right thing to do is replace them are they brand new?
i have seen them soaked in kero and cleaned with break cleaner
better off replacing them
but you could wash in warm soapy water then rinse in metho
vwo60 ·
There is a specific cleaner in a pressure pack called Brakleen, a CRC product, works pretty well, you cpuld put them in a warm oven after you clean them to see if any more oil comes out of the brake linnings.
Aussie Dubbin ·
Him much material is left? Is it worth machining down. Last on checked they Are cheap as buggery to replace
greedy53 ·
mate they are the only thing between you and a big tree replace, they are not price
grogy wrote:hi, is there any way to sucessufuly clean shoes covered in oil. thanks greg
Yes, there is a CRC product called BRAKLEEN in a pressure pack
that brings the oil to the surface..
recommended...
beetleboyjeff ·
Does it work on clutch plates too?
AA003 ·
Remove and soak them in metho and set fire to them. Do not use kero. Use Brakeclean after as I doubt if it would work by itself.
shaihulud ·
Do not use kerosene it is oily.
Soak them in petrol for several hours and set fire to them several times.
If they still exude oil, get new linings.
It's worth a try.
beetleboyjeff wrote:Does it work on clutch plates too?
Hi Jeff
I believe Brakleen works on clutches too...
although whether it works on metallic clutch plates???
but the other type.. YES... [used to be asbestos]
