66 Type 3 Notch Project
https://forums.aussieveedubbers.com/threads/94904/66-type-3-notch-project
smurf0 ·
Due to following the well trodden path of big dreams and then changing priorities I am putting my notch project up for sale. It was to have a non turbo EJ installed so there are many parts available for that also.
The car is almost completely disassembled. There is no engine. The transmission was pulled down to check it out and install a 4 spider diff and 3.88 final drive. It is all back together now and reinstalled in the floorpan.
The body was sandblasted apart from the roof and all panels so any rust is clear to see. There will be a bit of work needed in a few spots but nothing extreme. Body is now in primer. I will put some pics up soon.
The floorpan has been stripped and then POR15'd and is in the process of being reassembled.
Other parts available:
Late model Type 3 front beam with 4 stud front disc brakes
All the parts for the fuel injection are there.
An alloy radiator and dual fans.
5 bar rear end bracing
4 stud rear disc brakes from John Sherman and dual circuit master cylinder.
Volks Conversions EJ adapter kit with adapter plate, fly wheel and clutch.
If you are in the market give me a call on 0424319024 to arrange to see it.
It has cost me over $10k so far and I would be happy to take $4k for the lot or negotiate if some of the extras are not wanted. I will only sell parts if there are any leftover after the body and floorpan are gone. I have a trailer to transport it around Perth if needed...
Shane
