Ian C
Brisbane, 4012
0404874097 or PM me if genuine
Some of you may of been following my SC rebuild thread, finally finished it and got it rego'd last Fri. Well, I can't believe I'm doing this but just found a DC to restore s o this is up for grabs.
I'll try to be brief ............
underbody repainted
Hi opac unicryl paint
new steel in treasure chest floor
new 40X40 SHS ribs welded in for tray
New 50X50 angle welded in on tray edge
16mm External marine grade ply with 4 lacquer coats top and bottom
Marine grade UV stable carpet held down with 20X20 aluminium angle
SS eylets around tray for tie down
New cab floor welded in
All new accelator assembly and cable
New clutch cable and clutch
New rear brakes and cylinders
New uphosred seats
Power windows
Central Locking
New Bosch wipers and blades
New lenses all round
Polished jelly bean rims with new 195 rubber
New rear KYB gas shocks
New CV joints and boots
AS case with new 87.95 piston cylinder kit
SS pusrod tubes
Cro-Mo pushrods
New MOFOCO 042 heads 40/35.5 valves. match ported and polished
Italan Weber 40's with all manifolds tapped for booster.
Empi link kit
balanced fan
Vintage Speed SS exhaust
Vintage speed Black mamba CNC shifter
gloshift sweep gauges oil/batt/tach
All new german rubbers throughout
New carpet
New hoodliner
New sunvisors
Steering wheel is SHIT!!
Have both front and rear bumpers but need to be blasted and rechromed/painted (you can do that)
New doorpanels (one of a kind) ;-)
No glovebox (you can find one)
Get the whole thang from go to whoooahhh here
http://forums.aussieveedubbers.com/viewtopic.php?tid=93336
You can see how much work has gone into this so please don't lowball me, I'm not desperate to sell it so only talk to me if you are genuine. If you are legit I may move a little for you .
$13K including 6 months rego
Thank you
binner ·
