electronic speedo
https://forums.aussieveedubbers.com/threads/95081/electronic-speedo
donn ·
I'm thinking of replacing my VDO mechanical speedo in the wench with an eloctronic job as the existing one has been playing up for a while, any experience, cost, brand, alterations to loom etc?
PS it
the existing is not an original VW unit.
64vwmark ·
I use a Speedhut GPS speedo in my buggy. It was really easy to wire up and is really accurate as it uses a GPS signal. All you need to do is to connect it to the power and it will work.
http://www.speedhut.com/gauge_products-gauge_type-speedometer_GPS.htm
You can get them to customise the gauge faces too for not a lot extra.
bnicho ·
I've got a VDO Cockpit 85mm electronic unit in my Moke with a VDO/GM universal sender adapted to the gearbox. The same sender fits a VW speedo cable, you will find info on it on this forum.
It works well, except the needle bounces a bit on rough roads. Almost infinitely programmable for different tyre sizes too.
I actually have a spare speedo I should get around to selling. I bought another one as I thought he first one was faulty. Turned out it was my sender that was the problem.
donn ·
So bnicho, IF you got around to selling it what would be the $
vvwbeetle ·
not sure if this is of any help but just saw it on ebay - not sure if the do one for right hand drive
http://www.ebay.com.au/itm/DAKOTA-DIGITAL-DASH-58-77-VW-VOLKSWAGEN-BEETLE-GAUGE-CLUSTER-w-BEZELS-VFD3-VW-/370579604527?pt=Motors_Car_Truck_Parts_Accessories&hash=item564844042f
cam070 ·
vvwbeetle wrote:not sure if this is of any help but just saw it on ebay - not sure if the do one for right hand drive
They must be made for subi powered beetles as they have a water temp gauge.
vvwbeetle ·
Im guessing its a stock cluster
here is the company website
http://www.dakotadigital.com/index.cfm
(Not cheap stuff by the look of it)
donn ·
They must be made for subi powered beetles as they have a water temp gauge. [/quote]
the water temp gauge that usually comes with the digital dash system can be exchanged for an oil temp or transmission temp gauge
Still, abit too exie for me, I only need the speedo, the rest would be a waste and wouldn't fit in the miniscule dash in the wench. Thanks anyway. Just found this, pity it's MPH
http://www.ebay.com.au/itm/190631447496?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
blutopless2 ·
64vwmark wrote:I use a Speedhut GPS speedo in my buggy. It was really easy to wire up and is really accurate as it uses a GPS signal. All you need to do is to connect it to the power and it will work.
have you had any problems in high rise areas with respect to GPS signal?
Just wondering driving through a city whether signal loss would be an issue as it can be with some Sat/Nav systems.
vwo60 ·
I just bought a autometer KPH speedo from the states,$247.00, sender was $68.00. i also run a pricol speedo in my other car with no issues, been in there for 6 years
bnicho ·
donn wrote:So bnicho, IF you got around to selling it what would be the $
$100 posted Don?
It's the same as this one:
VDO Speedo
vlad01 ·
I bought a custom ETB electronic speedo. its fully programmable and the needle is servo driven rather than galvanometer style, so more actuate, faster response and don't bounce on bumps.
I haven't used it yet though 😁
donn ·
$100 posted Don?
VDO Speedo
Sounds good, is it a simple fit in or will I need other components, ie, is it complete?
thanks
Don
It is KPH I assume
cam070 ·
Donn you will need the hall effect sender to change it from mechanical to electronic.
bnicho ·
donn wrote:Sounds good, is it a simple fit in or will I need other components, ie, is it complete?
thanks
Don
It is KPH I assume
Hi,
No, it's MPH not KPH, as per the photo as I bought it in the States. Although you could calibrate it as KPH (ie: up to 120 kph instead of 120mph) if you wanted to.
As already said, you will need a speed sensor to provide a signal for the speedo.
donn ·
Bugga, thanks anyway bnicho, looks like I'll spend $ and get the existing one refurbished.
