mk2 8v starts but wont run??
https://forums.aussieveedubbers.com/threads/95087/mk2-8v-starts-but-wont-run
kombibob ·
Hi Guys,
Was driving the Mk2 today it was running fine but after grabbing a feed we jumped back in and found it would no longer run??
Engine turns over, starts, runs for a few seconds and dies, both pumps seem to be working and seems to be getting plenty of fuel to the rail.
We got it towed home tried it again and it was the same but after a few attempts i had it running and revving fine for a few minuets but it ended up stalling and going bad again. Even changed the fuel filter out in the rain tonight with no luck.
We have had a couple of weeks of wet weather so starting to think elec gremlins.
Any ides??
_________________
sounds like fuel pump, doesn't the Mk2 have a lift pump in the tank, they were trouble 10 years ago.... or is that a mk3?
Efi fue pressure has to be exactly right, check pressure and if incorrect, can be pump or regulator.
kombibob ·
Hey matt, yep lift pump is working, but I will test pressure after work to make sure.
kombibob ·
well came home to work on the bloody thing but in true Volkswagen fashion the problem seems to have gone??
Started and ran straight away so i took it for a run and it didnt miss a beat. but i did notice a dirty fuel kind of smell from the exhaust while idling just after the first start up.
So now thinking water in fuel??
greedy53 ·
dont know if anyone will believe me bu tit worked for me after my dad told me about iti once had amy share of water in my tank so i poured a bottle of metho in and never had anymore problems wont work with a guts full of water but it did work and only cost me $2.00 mit be worth a try
OZ Towdster ·
Check the earths too bob as if it's got a loose or dirty earth some where the ecu won't like it much which will cause intermitant faults
