Has anyone tried one of the replacement 34 pict carbs on a stock twin port engine, I know they are made by Empi and come from China and with Empi's track record at selling shite quality parts I am a bit worried about fitting one, the original carb on this engine is not repairable so we need to get something.
I need some input from someone who has run one of the empi replacements so I can decide what to do, or if anyone has a good original 34 pict3 and manifold let me know.
grumble ·
I had a customer who fitted one,he had a s..load of trouble with it and after 6 months bought a used carb from me and fitted that to fix the problem. Cheers Les
Menangler ·
Thanks Les, this is what I expected, but needed to know for sure, will try and get a good used one.
REDKG ·
same deal, new empi carby couldn't get it to work (now an expensive paper weight) so got an old german one rebushed and works perfect.
annosL ·
Ditto for me too, couldn't tune it so rebuilt the old one
LUFTMEISTER ·
The new ones have a separate idle circuit. you will need to solder up bleed hole in throttle plate to operate properly.
grumble ·
Menangler wrote:Thanks Les, this is what I expected, but needed to know for sure, will try and get a good used one.
I will have a scratch around there may be one in fair condition in the shed.I will let you know if there is. Cheers Les
bigdave ·
I looked around for a “good used 34pict” but soon realised no such beast exists. Updated to a 32/36 Weber and very happy with it.
