As the title says
Coming from the right side of the engine
It's a 1300 single for in my beetle
Engine is otherwise in good nick, was rebuild about 6 years ago and hardly driven
I've checked all the engine tin to see if that was squeaking, but it isn't. And as it increases with revs and kind of pulses, I'm thinking it's probably mechanical
Any ideas???
It's driving me nuts!!!
Ben386 ·
Its not pinging,is it??
Mattriots ·
Ping?? As in running lean??
Dunno, how do you check??
Ben386 ·
Check your timing,check vac advance.
What fuel do you use?
I wouldnt describe pining as a "high pitch pulsing squeak"
Not the fan is it??
Try taking off the fan belt and fire it up and see if you can still hear it
Mattriots ·
I did a bit of research, I don't think it's pinging, doesn't that sound more clunky??
It sounds like sheet metal on sheet metal squeaking, but it increases with the revs
I've pushed and pulled on everything while the car is running, but the sound doesn't come or go, it stays the same, just a pulsing squeak squeak squeak squeak squeak squeak squeak squeak squeak
If it's a whistle type of squeek , I'd go with inlet manifold leak at the head or carby, or even loose head.....
Ben386 ·
I suppose more of a metallic rattle than squeak.
Not an exhaust leak??
generator / alternator bearing??
again - try disconnect fan belt
Mattriots ·
It ain't the pulleys, sound is coming from below there
And you can still heard it well from under the car
Also I can't feel any exhaust leaks
I'm hoping it's some tin work loose and not engine internals
I'll re check the tin tomorrow
Mattriots wrote:As the title says
Any ideas???
Do You have a Gun...??
a big gun.... a special magnesium alloy gun....
pump about 6 shots into the RHS of the engine...
If any big rats run away.....
that was the problem.... If nothing happens...
keep asking..
Sides ·
I'm with Matt - describing it as pulsing sounds like an intake leak to me.
Won't be an exhaust leak... they give a boom'y sort of phutt sound... make the engine sound like a tractor.
Check the intake manifold is tight to the head, and that the head studs are all tight.
Sides ·
Any ideas???
keep asking..
Umm... OK... think Lee might be somehow related to Gremlins... don't let near a keyboard after midnight !!!
ok - if it is a "choofing" sound it may be a cracked head.
I had this the other day
Pull the sparkplugs and see if there is a "V" black mark
This was causred by a crack in the sparkplug thread
Mattriots ·
Just changed the plugs and it still makes the noise
I'll check the intake bolts are all tight
Mattriots ·
Intake manifold is tight
Ah stuff it, this is a job for the mechanic, I quit!!!!!!!
ragged ·
Matt, drive it up and let me have a listen. I've built one or two engines!
Cheers Dave
Mattriots ·
Will do Dave, thanks
I've justt gotta get my wheels back from the painters, so maybe in a week or so, I'll give you a call
beetleboyjeff ·
Mattriots wrote:I've justt gotta get my wheels back from the painters in a week or so
There's your problem - it is the brake drums skidding on the road when you downchange. 😂😂
Mattriots ·
But it's the best way to lower a beetle, roll on the drums!!!!
I'm gonna do the garden hose stethoscope trick tonight, fingers crossed it a dodgy intake gasket, I don't want a leaky head!!
Chirp chirp
Mattriots ·
Ok so I just did the garden hose stethoscope trick, didn't find anything but a couple of small exhaust leaks( empi gt stainless) but these were making more of a dull chugging sound, they didn't sound chirpy like crickets. I'm gonna fix those leaks but I don't think they are making the chirp.
Also no intake leaks, checked them with the hose and sprayed some starter fluid around, nothing
Couldn't find the noise anywhere around the head either.
Anybody have any suggestions?? Its driving me crazy!!!
Also, stupid question, but as this is my first vw, I don't really know.... But this chirpping cricket noise isn't a characteristic noise for these engines is it???? It's a 1300sp
Mattriots ·
Oh and I pulled the plug leads individually while the car is running, and the noise remained, so I seriously doubt it's engine internals
matara ·
I had a problem like this that had me stumped for ages. In the end it was the pushrod for the fuel pump that was wrong. I had a replacement pump that I thought was for a generator, but was actually for an alternator. The pushrod needs to be changed to suit and because it was a bit too long it cause a metal on metal squeak. Thats why the squeak became faster as rpm rose.
Mattriots ·
Good option! I'll look into that
Also just noticed that the flanges on my stainless empi exhaust aren't welded all the way around the pipe, just tacked!!! There is definite carbon deposits on the outside, I'll weld that up, see if that's the mystery chirpy bird
vlad01 ·
could be rocker failure in the works.
greedy53 ·
only a guess but take the belt off and see if it still does it,it's a start
Mattriots ·
I'll give the fan removal a crack
But I doubt it
Mattriots ·
Problem solved!!
Dodgy empi welds on the exhaust where the heater riser flange is.
Re welded it and now no more chirpy birds
Thanks for your help guys, no more empi crap for me in the future!!
