Looking for a complete pedal assembly for my 65' T1.
Brandon
Indiana, USA 47615
vdubbles24 ·
Christoper
PM sent. Hope I did it right.
Brandon
vdubbles24 wrote:Looking for a complete pedal assembly for my 65' T1.
Brandon
Indiana, USA 47615
Hi Brandon,
I sent one set over to a fellow about a year ago...
didn't charge him anything... but it cost about $80US postage back then....
the RHD pedals do NOT wear out like LHD pedals...
WE have long shafts instead of short shafts that wear out..
I don't have a set of pedals now but many people would have them... as I said, Ours don't wear out... lol
so they aren't thrown away... lol
vdubbles24 ·
That price would be awesome!!!
Shipping is between $80-$90 USD so it hasn't changed much. I would so love to get my hands on a "no charge" set. I have parts up FS/trade
Let me know what anyone might need that is hard to find your way.
Thank you so much for your time
Brandon
vdubbles24 ·
I'm learning the site. Slowly. Still trying to figure out the for sale ads.
RHD pedals needed!!
vdubbles24 ·
Bump.
Keep this thread active. I really need a reasonably priced set if pedals.
coletrickle ·
I've just moved all my stuff into a 20 ft container and there were some pedal sets in there.If they are eaisly accesable they are yours.Will be back to the container mid next week and ill have a look shouldn't be a drama.Will let you know
lauw58 ·
Hi sent you an e-mail
vdubbles24 ·
lauw58 wrote:Hi sent you an e-mail
PM sent
Brandon
vdubbles24 ·
coletrickle wrote:I've just moved all my stuff into a 20 ft container and there were some pedal sets in there.If they are eaisly accesable they are yours.Will be back to the container mid next week and ill have a look shouldn't be a drama.Will let you know
Email sent your way.
Brandon
Brandon
Hey Brandon, tip of the day, Col doesn't do email real well, I'd recommend send a PM. He's stuck in the analog world.....😂
vdubbles24 ·
Brandon
Advice takin!!
PM sent......
Thank you
Brandon
HappyDaze ·
Hey Brandon, make sure you have a RHD steering wheel.
Special Air Service ·
HappyDaze wrote:Hey Brandon, make sure you have a RHD steering wheel.
Greg,
He's American not Irish!!!!! 😂
vdubbles24 ·
Aw man.
Were do I find a RHD steering wheel????
Jk pretty good though. I got buddies that would fall for that!!
vdubbles24 ·
Cole
I sent a pm again! Lol
If it doesn't work please feel free to email me directly.
Thank you
Brandon
HappyDaze ·
vdubbles24 wrote:Aw man.
Congratulations, Brandon......you've passed the 'sense of humour' test [that's the proper way to spell humour, by the way]. You will need it to survive on here.:crazy.🤪
vdubbles24 ·
Found a RHD steering wheel. Looked for 2 weeks. Man they are rare!!
Lol
Still in search of pedals. Just incase Cole doesnt have any.
If you guys need any parts from the states hit me up please.
Feel free to txt anytime
1-812-393-9920
Idk if or how international text work but I'll give it a shot.
Brandon
vdubbles24 ·
Guess all my post are gettin ignored now?
Wow.
vdubbles24 ·
Bump!
I know someone can help me out. Please
Brandon
Yogie ·
Someone else may be able to confirm but, are the pedals for the mid sixties beetles the same as the later ones (68 -72). I have only ever had the later ones so don't really know.
Yogie
vdubbles24 ·
There for my 66' beetle. But from my research they should work mid 60's up into the later years. Plus the later ones are stronger. I just need a complete set for my RHD rat rod.
Yogie ·
If they fit, I am pretty sure I have a spare set. I will check over the weekend for you and let you know.
Also, there is a flat bar that welds to the floor to reinforce the strength there for the pedals. I don't have one of them available but you should be able to make one out of thick plate. On top of that, there is a nut welded on the underside of the pan for the bolt to go through that holds the tension on the clutch return spring.
Have you seen these and do you need any measurements to help locate them on your pan?
Yogie
vdubbles24 ·
I've seen several pics and I talked to a fella a few years back on thesamba that was from Australia he posted some pics in a thread that I saved.
Thank you for your time. I appreciate it.
Pm sent
Thanks again
Brandon
Yogie wrote:Someone else may be able to confirm but, are the pedals for the mid sixties beetles the same as the later ones (68 -72). I have only ever had the later ones so don't really know.
Yogie
This is an interesting point.
Our pedals are the same'57 - '67 , these are the cast style. The later pressed metal style fit '68 >. the clutch tube is in a different spot in the tunnel so it is necessary to have the correct set. If your bug is a US '66 model, my guess is it's the later style you need. Maybe you can measure the depth of the clutch cable tube from the side of the tunnel in your pan.
57 Chook Shed ·
You'll also need the rhd accelerator (gas) pedal as its different, also you'll need the hinge part of the pedal that welds to the floor (lhd mounts to the casting on the pedal assembly), you'll also need to weld captive nuts in the rh side of the tunnel, either side of the new hole you'll have to cut for the pedals. You also need a rhd pitman arm on the steering box and a rhd speedo cable.
The small plate that was mentioned in a previous post is the pedal stop plate, nothing to do with the spring.
Graham.
vdubbles24 ·
I've found several RHD gas pedals here in the states reasonable. I cut a pedal mount section out of a old pan so I was gonna graph it in.
