aintgotitmusthaveit wrote:Hi guys,
I have ought a new exhaust and the J tubes are about1-2mm smaller in diameter than the mating tube- so big that it doesnt seal and sucks air in off throttle (causing abackfire!)
How do I seal it?
Will exhasut cement work?
RTV silicon during assembly?
or do I try the silicon coulers used on intercoolers and the like.
I tried lagging it ip and it worked a bit but the lagging got shagged.
Yes You can use RTV Silicone [silastic] I use it on my exhausts
all the time... info came from an exhaust fitter.. used it when fitting extractors to cars...
nothing happens to it.. doesn't fall off etc or burn...
just make sure its 100% clean metal.. I use alcohol swabs to clean the metal... never have any problems..
I still use gaskets but they haven't been any good since they took the asbestos out of them.. lol
I let the silicon nearly cure then do up the bolts/nuts etc..
and Yes those stupid VW exhaust clamps were good in 1939
not so good in the 21st century ..lol
