case stud got pulled out?
https://forums.aussieveedubbers.com/threads/9536/case-stud-got-pulled-out
de_ja_vu ·
how do i fix a broken case stud? which case-saver should i use ? what size should i drill?? etc.. etc...
the engine is t-1 1300 engine 10mm studs
thank you...
Did the case have case savers to start with??
If so i believe you can hhave them put in and go fron there.
If you already have them you will have to go with the 12?mm stud and saver
