bajachris88 wrote:Hello again,
i'm ironing out all probs on the baja before valla comes, and one in particular is the brakes pulling the car left. its definitely in the front (did a handbrake test :P). I have a 1969 with stock disk brake front.
Is there any tips for the debugging of such? its a newlie developed problem and feels as though its getting worse over time, and i'm a newbie to such probs.
all advice would be much appreciated 馃檪. Thanks heaps in advance.
Hi Chris
Yes most probably a stuck piston in the caliper... which means no braking at that wheel whatsoever....
see if You can push the caliper piston in with a clamp
brakes unbolted but still attached to the car...
or faulty master cylinder... does fluid come out with the bleeded undone slightly and a push on the brake pedal??
I know it all comes down to money Chris..
I built My beetle over 10 years lol... [medical reasons really] but had lots of time to buy new brakes etc... hoses etc..
so it drove and stopped like a new beetle... which is pretty good..
beetle brake problems can drive You around the bend.. lol
even new parts and bleeding the brakes is usually a headache...
best of luck
PS: some one mentioned using clamp or vicegrips on brake hose..
this is OK if You are going to replace the hose later... lol.. LEE
