Fuel Line Clamps
https://forums.aussieveedubbers.com/threads/95442/fuel-line-clamps
AA003 ·
Does anyone know where to buy these type of clamps in Sydney.
Norma/ABA brand.
snitz ·
Just a quick search and it came up with this link..
http://www.google.com.au/url?sa=t&rct=j&q=norma%20clamps&source=web&cd=1&ved=0CDsQFjAA&url=http%3A%2F%2Fwww.norma.net.au%2F&ei=gZNAT8aPAoyviQf2kdy6BA&usg=AFQjCNFWIE5-cch61PuWuKR6NRuCLcEVzw
It looks like you can order online and has pricing..I might have a gander and see if theres nominated stockists in NSW.
snitz ·
Below Contact us is the link for the online store..looks like the mini bore clamps are sold per 10 units..hope this helps you.
AA003 ·
The problem is that I just need to try sizes first. 10 clamps will cost $30. If I get it wrong $60.
I use them on My fuel lines but bought them many years ago..
they also made normal types of hose clamps..
from stainless steel... also small fuel line ones with the band painted blue...
someone should have them...
they have the size stamped on them like 12-18mm
which I presume is the outside diameter of the hose..
robb ·
have you tried pertex
AA003 ·
robb wrote:have you tried pertex
No luck there.
57oval ·
Try Autobarn, i bought some for my 6mm fuel lines, $2 ea
DubCty ·
They are a fuel injection type hose clamp, Id try any automotive parts place, Repco??
robb ·
mate thats a suprise i thought they had it all when it come to that gear
AA003 ·
57oval wrote:Try Autobarn, i bought some for my 6mm fuel lines, $2 ea
Can't find any fuel line clamps at all there.
Australian Fuel Injection 3 / 79-81 Boundary rd Mortdale 9534-5222
AA003 ·
vw54 wrote:Australian Fuel Injection 3 / 79-81 Boundary rd Mortdale 9534-5222
They only have crimp type.
grumble ·
Bursons or Repco stock the Norma clamps, the crimp clamps work better on the standard fuel hose.
AA003 ·
grumble wrote:Bursons or Repco stock the Norma clamps, the crimp clamps work better on the standard fuel hose.
Yes the crimp type work great but they are hard to remove on a WBX motor. 4 hours to remove a water hose clamp. Ended up using a dremel to grind it off. If you are away from home it would be near impossible to replace a hose.
Thanks for the information but Repco don't sell them.
Hi Phil
How about these ones.
AA003 wrote:Does anyone know where to buy these type of clamps in Sydney.
Norma/ABA brand.
I also use ABA made in sweden fuel line clamps..
bought many years ago...
any luck yet?
AA003 ·
68AutoBug wrote:any luck yet?
Yes Lee I've bought these for $32.70 for 10 delivered.
ABA Clamps
The 13mm ones fit the water hoses perfect.
Matt Ryan ·
I use thumb screw clamps, less than $2 from memory. At Bunnings in the garden watering section. Thumbs are colour coded for different sized clamps but you can swap the thumbs around to get the colour you want.
I find it very re-assuring to be able to reach in and check my fuel lines by hand any time I have the deck lid open, rather than waiting for the times I remember to do it while I happen to be holding a screwdriver.
Regards,
Matt.
excellent Matt..
I sometimes forget to retighten the hose clamps..??
and as You say, need a screwdriver in Your hand and need to be able to access the screw in the clamp..
Have never seen those type before..
