WTD complete link pin beam
https://forums.aussieveedubbers.com/threads/95462/wtd-complete-link-pin-beam
ashbaxter ·
Im after a complete narrowed (2") adjustable link pin beam with spindles ready to bolt in.
What's out there?
Cheers ash
Call VVDS 02-9789-1777
No Dunes ·
Classic Veedub will have some narrowed beams in next week .... 2.5 inch drop spindles on sale $99
Dasdubber ·
Obviously there are quite a few options out there.
We sell Airkewld products inc the made-in-USA 2in beams (which include narrowed torsion leaves AND narrowed tie rods):
http://dasrestoparts.com.au/suspension-and-steering/beetle-suspension-and-steering/front-suspension-and-steering/front-ends-and-components/airkewld-ultimate-narrowed-beam-2-inches-beetle-1945-1965.html
Or the cheaper Empi 2in beams:
http://dasrestoparts.com.au/suspension-and-steering/beetle-suspension-and-steering/front-suspension-and-steering/front-ends-and-components/2-narrowed-link-pin-beam-with-adjusters.html
And torsion leaves:
http://dasrestoparts.com.au/suspension-and-steering/beetle-suspension-and-steering/front-suspension-and-steering/front-ends-and-components/narrowed-leaves-f-link-pin.html
Spindles are a week or so away (but I'm sure you can get them from George or VVDS if urgent). Note you will need the new (get German) king and link pins and will need your spindles pressed apart and then mated to the new dropped spindles.....they are not a full bolt in deal - for example the pic of the CB Performance spindles tells you what you get:
http://cbperformance.com/catalog.asp?ProductID=486
Al
DAS Resto Parts
christopher ·
If you want quality go with the Airkewld Beam,just installed a 3 inch in my Buggy.
ashbaxter ·
Could you supply it with stock spindles German king pins and disc brakes and if so at what cost
Dasdubber ·
Hi Ash, we only stock the higher quality disc brake kits (CSP and Airkewld) - CSP we have in stock currently:
http://dasrestoparts.com.au/brakes/beetle-brakes/front-brakes/disc-conversions/disc-conversion-kits.html
These are to suit CB Performance dropped spindles though (which are a week or so away as mentioned above) along with the German king/link pins (due in same order we are waiting for). You can get the cheap Chinese spindles but I have seen these flog out after some time (there is a guy on Melburgluft who had a similar problem). Likewise you can get the cheap wide 5 disc brake kits - your call at the end of the day.
There is always a reason why the quality parts cost more, and a reason why we don't stock the other stuff.
If you were keen on a full setup (beam, brakes, spindles etc) we'd be more than happy to do a good deal for you - if genuinely interested shoot me an email (alan@dasrestoparts.com.au)
Al
