Bleeding Brakes
https://forums.aussieveedubbers.com/threads/95549/bleeding-brakes
TorxKiwi ·
1975 L Bug has the front calipers with two bleed screws/nipples/valves, whatever the correct name for them is. I was bleeding them today and one side is fine but on the other side the bottom one is blocked. I tried loosening it, nothing came out. Removed it, nothing came out. Do I need to rebuild, replace or just clean. If it's clean where can I find the procedure?
Thanks in advance as always.
ian.mezz ·
you bleed brakes from TOP nipple only. some brkes have 2 nipple so they can be fitted to any side.
ian.mezz ·
TorxKiwi wrote:1975 L Bug has the front calipers with two bleed screws/nipples/valves, whatever the correct name for them is. I was bleeding them today and one side is fine but on the other side the bottom one is blocked. I tried loosening it, nothing came out. Removed it, nothing came out. Do I need to rebuild, replace or just clean. If it's clean where can I find the procedure?
you tube is your friend.
TorxKiwi ·
Great ..... Newbie mistake 😀
