Loose volume control screw- H30/31
https://forums.aussieveedubbers.com/threads/95553/loose-volume-control-screw-h3031
Mattriots ·
Just bought a brand new H30/31,
I'm trying to tune it, but when I back out the volume control screw the required 2.5 turns to het it to the starting point, its is very loose.
Infact when the engine idles the screw jiggles around
Anything over one turn out from a snug seated position feels loose
Any ideas??
Can I tune it and then plug the screw with something or locktite it so it won't move??
pod ·
is the o-ring still in there?
ditto ^^^
I have had a pict where the screw just went walk about
New O ring and all good
Mattriots ·
Does the o ring sit behind the screw or is it visible from the outside??
I can't see one, but I have not completely screwed it out
it sits on the screw
You need to take it out and there should be an O ring sitting on the screw
My guess is it is either missing (but this is new?? "new" never ceases to amaze me) or it is somehow squashed/shagged/flat
This is a Weber ADF mixture screw - but you get the picture
Mattriots ·
O ring is there, just checked
But it doesn't seem to be sealing properly
Either the o ring isn't big enough, or more likely the hole has been drilled too big
An ideas on a fix?? Should I try and get a bigger o ring? Do they even make them with the same ID but bigger OD??
Mattriots ·
My vol screw has a cone on the end, then it goes the the threaded section, then there is a step up in diameter with a recess cut into it where the o ring sits
It
Doesn't sit on the threaded section
Mattriots ·
It looks like this
http://www.google.com.au/m/search?site=images&client=safari&hl=en&gl=au&source=mog&aq=f&oq=&aqi=-k0d0t0&fkt=6809&fsdt=7924&cqt=&rst=&htf=&his=&maction=&q=carb+volume+mixture+screw+31pict#i=15
Take it to a carb shop
They will have a heap of O rings
Hopefully it is just a dud O ring
It happens
like this??
Mattriots ·
Pretty much like that!
The o ring is in perfect condition, I think the hole in the carb has just been drilled too big
I'll try and source a bigger o ring tomorrow
