what oil??
https://forums.aussieveedubbers.com/threads/95669/what-oil
Tas67 ·
i have just purchased a 67 beetle that has been in a shed for the last 10 years, one of the front wheel was seized (brakes) and i have that sorted. i put some fuel in her a new battery and some aero start and bugger me dead she started and ran well enough to drive on the trailer...my question is...what sort of oil does everyone use in the older beetles??
thanks
I use and recommend ACE Air Cooled Engine oil. Australian made and has all the properties required for long life.
http://www.qplubes.com/index.html
^^^.... yep, I use ACE as well
that and Nulon 10/30
vwo60 ·
Penrite HPR 30, readily available and a good oil, used it for years.
tar76 ·
I'm keen to try ACE but could never find it!
I stock it Tarin, 5 litre or 20. 🙂
tar76 ·
matberry wrote:I stock it Tarin, 5 litre or 20. 🙂
Excellent!! Might get you to give the bug a drink of it when i get it up to you
vlad01 ·
vwo60 wrote:Penrite HPR 30, readily available and a good oil, used it for years.
yep, now fully synthetic 👍 good oil.
Next engines will be upgraded to Joe Gibbs oil for me though, even better by a long shot.
A pointer for you folks is stick to one oil brand and type, otherwise changing brands can do its damage by additive chemistry clashes.
And don't use caster oil, its no good for the engine 😂
vlad01 wrote:now fully synthetic
As if VW engines don't leak bad enough already 😂
vwo60 ·
I just bought forty liters and that was a minerial base not synthetic
http://www.penriteoil.com.au/products/engine-oils/hpr/hpr_30_premium_mineral
waveman1500 ·
Any decent name-brand 20W50, as long as it's clean! I like to buy Nulon or Penrite because they're Aussie-made and owned, but the most important thing is to change it regularly! Buying cheap oil and change it every 5,000km will be far better for your bug than putting fancy oil in every 10,000km.
20/50w is fine in one getting a bit long in the tooth but that's like tar in a fresh motor.
Anyone leaving oil in an air cooled engine for 10,000kms needs their VW taken away from them.
Even fancy oil is cheaper than rebuilds.
It says in the original owners manual for our 1302.
Regular oil changes are required even if the best brand of oil is used.
Change every 5000km
Oil consuption is 0.5-1.0 liter per 1000km
AA003 ·
vlad01 wrote:yep, now fully synthetic 👍 good oil.
Synthetic not really good for air cooled engines.
Poor heat transfer qualities.
vwo60 ·
If you go to the link you will find that HPR 30 is a minerial based oil.
Tas67 ·
Thanks for the info guys.....heaps of stuff to research
YES MOST important...
always use the same brand of oil...
no swapping about...
NOT GOOD....
and synthetic oil isn't recommended for air cooled engines.
and You still NEED to change the oil at every 5000klm maximum...
as recommended by VW Mexico in 2003..
and Me.. .LEE
YES I agree Joel
synthetic oil isn't recommended for air cooled engines...
they will leak from places they didn't leak before...
best to stay away from them...
vlad01 ·
who said I use it in a vw engine? you should no this since you got suby horses in yours.
vlad01 ·
vwo60 wrote:If you go to the link you will find that HPR 30 is a minerial based oil.
it is now, bought a bottle of it 3 days ago and it says on it "now fully synthetic"
win!👍
