Aussieveedubbers · Bugs
Best oil
https://forums.aussieveedubbers.com/threads/95688/best-oil
Sbug 71 ·
G'day Dubbers
I've got a near new 1916 which is coming due for an oil change. I would like your thoughts on what oil I should run in it.
Any info would be greatly appreciated.
Cheers.
tar76 ·
Ace 30, seems to be the go mate. I checked out their website and looks to be a good oil .
Sbug 71 ·
Thanks Mate.
I'll have a look at it.
Sbug 71 ·
Can anyone tell me where I can buy Ace 30? I also discovered that there is Ace 40 as well. Interested to know peoples experiences with these and other oils used.
Cheers.
cnfabo ·
castrole edge 20w/50 with some of that molly lube additive,cant go wrong....
Lucky Phil ·
Pennzoil HPR 30 for me.
whathaveidone ·
whatever is on special😀 just change it regularly.
vwo60 ·
Penrite HPR 30 ,readily available oil with a good zinc content for flat tappet cam engines, cheapest part of your engine is the oil.
thebugnut ·
I agree with vwo60.
You should NOT use synthetic oil until the engine is broken in and the rigs are seated or it can cause problems.
An oil with zinc is important. Most oil manufacturers have taken most of the zinc out to save money as modern engines all have roller tappets (or lifters, cam followers) and the zinc is what lubes them. Cams tend to wear out faster nowadays without the zinc.
vwo60 ·
I work in the oil industry and i cannot believe that mono grade oils are said to be the best, i always run the penrite HPR 30 with out any problems, i even use it in my briggs and stratton that has been flogged for 15 yerars with only oil changes that are carried out regualy, i bet if i ran a mono grade oil as recommended it would not have lasted this long.
Topaz ·
vwo60 wrote:I work in the oil industry and i cannot believe that mono grade oils are said to be the best, i always run the penrite HPR 30 with out any problems, i even use it in my briggs and stratton that has been flogged for 15 yerars with only oil changes that are carried out regualy, i bet if i ran a mono grade oil as recommended it would not have lasted this long.
So what grade do you recommend for a old tired 1600? I was told any 20W-50 ❓
vwo60 ·
http://www.penriteoil.com.au/products/engine-oils/hpr/hpr_30_premium_mineral
It is a 20W-60 but it is designed to run were you would use a 20W-50, you can phone a engineer at penrite and talk to him about your use and get a recommendation from them. if your engine is tired you might be able to use any 20W-50, just check to see if it has a good zinc content.
Sbug 71 ·
Penrite HPR30 it is. It was also recommended to me outsise of this forum. That many people can't be wrong.
Cheers everyone for the responses.
whathaveidone wrote:whatever is on special😀 just change it regularly.
BAD INFO...
You should always use the same brand of oil....
Oils aren't the same...
if You use 'no brand' oil , Your don't think much of Your engine..
same as switching brands all the time...
A No No... IMHO...
20w/50 is usual.. some people use 20w/60 if their engine is worn a bit...
Zinc was taken out of the oils because its not needed in new engines... only flat tappets need it.. like VWs..
AA003 ·
thebugnut wrote:I agree with vwo60.
You should NOT use synthetic oil on aircooled engine.
(Poor heat transfer qualities.)
bajachris88 ·
Every oil change i 'personally' throw in a dose of Lucus Oil Stabilizer. Its added security incase a mass oil leak sends the bearings dry. And as its been mentioned, once you finally get that oil pressure warning light while your driving, its already too late (IE: damage been done).
I seem to attract bad events so the insurance of it is simply piece of mind incase the baja spills while i'm bashing about.
On the Lucus Oil Stabilizer website, it has testimonials and one in particular was a vw beetle doing a rally event. after loosing oil pressure with the oil light glowing not so far from the finish line, the competitors thought it was silly to pull out now when so close. Of course, expecting the engine to be toast. They finished the event, and upon tear down of the block, no damage was found 👍! well, there had to be at least a little, but so they say.
The stabilizer maintained that gacky membrane over the bearings to prevent full surface to surface contact. And you can't say the event of loosing oil pressure while driving doesn't happen, even Lee here has had an experience 😀
BiX ·
Just reading the penrite webpage.
the new 10 tenths oil seems to be a good option. It has a high zinc content and fully sen.
smithy68 ·
Are the penrite classic range of oils good for aircooled motors?
vwo60 ·
You can bypass all the advice on this fourm and talk to a engineer at penrite direct and discuss any issues that you have.
smithy68 ·
well they recommend the classic oils and not the hpr 30 for the standard engine on their website, so thats why I wanted to know if anyoene else used the classic range?
Thanks for info vwo60
ClockworkMonkey ·
never had a problem using hpr30 🙂 but then i just have a stock 1500 sp
vwo60 ·
I have a 2275, 2054 and 1776 and all have HPR 30 in them.
Personally I use Penrite HPR Gas Premium. It is the same as HPR 30 with extra zinc and potassium
57oval ·
smithy68 wrote:well they recommend the classic oils and not the hpr 30 for the standard engine on their website, so thats why I wanted to know if anyoene else used the classic range?
I use the Classic Medium, it is a bit more expensive than HPR30 and has more zinc content which is what you need.
smithy68 ·
That good to hear 57oval because I have a box of the stuff that was given to me , classic medium.
Think I'll be using it then.
Nikos ·
I've been using Penrite HPR5 (semi synthetic) 5W-40, on my new 1776 since Richard built is approx 2 yrs ago. Am I best changing now to the HPR30? It uses a little more oil than I'd like, which is not a problem so long as I keep an eye on things.
Nick.
DakDak67 ·
Brad Penn 10-w30 . The one and only.
ClockworkMonkey ·
might be a stupid question, but what does the zinc content do to the oil??
I used to use Brad Penn, now I use ACE, Aussie made, more available (than Brad Penn), and a true viscosity rating unlike the other oil prominantly mentioned above. I also found better oil pressure at temperature with ACE over Brad Penn and Castrol of similar viscosity.
Zinc and Phosphate (sp) often combined in the spec., are said to be required for lifter/camshaft longevety.
vwo60 ·
The zinc in the oil helps protect the cam follower's, it has become a issue with all flat tappet cammed engines as the oil manufactures remove the zinc so it does no damage the catalitic converters on modern cars. nikos i would run the oil you have been using as a change could increase the consumption
Nikos ·
Thanks for the feedback.
DakDak67 ·
matberry wrote:I used to use Brad Penn, now I use ACE, Aussie made, more available (than Brad Penn), and a true viscosity rating unlike the other oil prominantly mentioned above. I also found better oil pressure at temperature with ACE over Brad Penn and Castrol of similar viscosity.
I'll take your advice on board Matt, I wool rather support an Australian product.
tar76 ·
Got to do a oil change on the bus and i might change her over to Ace as well. Ace seems to be going all right in the beetle . I suppose the only negative is it's not widely available where you can just go down the likes of auto shop and buy it. Matt do you sell it in 5L ??
Yes mate, 5 litre and 20 litre on request.
tar76 ·
matberry wrote:Yes mate, 5 litre and 20 litre on request.
Cool Dude. i have been very impressed with Ace so i'll contact during the week, brother in law keen for some as well.
smithy68 wrote:Are the penrite classic range of oils good for aircooled motors?
what are they worth for 5 litres..?
have been waiting for local parts shop for a price..
I'm using Castrol magnatec now that Castrol has dropped castrol GTX2 and changed the makeup of the two GTXs...
I sell 5 litre of ACE 30 or ACE 40 for $40 +gst
tar76 ·
matberry wrote:I sell 5 litre of ACE 30 or ACE 40 for $40 +gst
Hey Matt did you use Ace 30 or 40 on Bud? I'm hoping i can keep the oil in Bud and the Bus the same so i'll use whatever left for tops ups etc..
Ace 30. All engines unless they are nearly kangarooted.
Carl and Emily ·
matberry wrote:Ace 30. All engines unless they are nearly kangarooted.
So would that be Ace 40 in my 62 Matt??😢
Carl, I just checked my records and Mary has ACE 30. Next change I'd put in ACE 40 as she wouldn't mind a thicker oil with her worn bearings.
JVLRacing ·
Royal Purple or Nulon...they have very good surveys on them
Governor ·
Google
ulx110
Well worth the money
tar76 ·
Black64 wrote:Google
ulx110
Interesting, have you tried it?
Governor ·
Yes and a number of mates have aswell, high zinc content perfect for VW engines.
It is a bit pricey but if you have just spent a lot on an engine its a small price to pay .
lenny1870 ·
http://www.datateck.com.au/lube/castr_au/default.asp
