Aussietrimmer ·
Hey guys have anyone fitted an Air unit into a 2 ltr Kombi I need some ideas
Aussieveedubbers · Busses
https://forums.aussieveedubbers.com/threads/95702/air-in-a-77-kombi
Aussietrimmer ·
greedy53 ·
MickH ·
Aussietrimmer ·
Thanks Guys gives me something to work with, do you have a pic of the pully on the fan?Joel wrote:Not many busses sold with A/C new but very very occasionally I see a bay window with original A/C still fitted.
Only over head consoles though, I've never seen one in aus with an under dash console though.
There was a kombi wreck (project apparently 🙄) on ebay recently, even the type 4 engine had the old piston style York compressor bolted to it still.
I was over at the subi shop several months back and a subi powered bay was up on the hoist.
It had original A/C so I grabbed a pic of the condenser.
WHen it was converted to Subaru engine though it was never hooked back up.
It wouldn't be hard to make up mounts and hang a modern serpentine condenser with some slim line fans the same way.
You could easy mount an under dash console too, they are availible new with various facias on them.
The main problem you have with a type 4 engine is the compressors are mounted to face the opposite way (pulley to the front of the car) so they get spun backwards.
Just for anyone who has never seen one they have a mounting location of the left side of the shroud and the belt is driven off a pulley fitted to the inside of the fan
Not a problem with old piston compressors but modern scroll ones can't run backwards.
Rotary ones may be a different story, I'll have to get back to you.
Or you could fab up brackets and a pulley system to mount one above the engine like this:
MickH ·
