Anyone know the sixe of IRS Trailing arm Bushings? Any one got pics/ info on how big trailing arms are! I need to get this info to the guys who are making some narrowed ones for the Bug!
Cheers N!
Jeza ·
Unity-28
Don't have the sizes on me, but you are in luck because I have both of the trailing arms out of my Beetle at the mo, and I've removed the bushes to.
I'll measure and post tonight.
Jeremy
Unity-28 ·
Cheers! If poss, the bolt hole as well (i might be pushing my luck!😀)
N!
Jeza ·
N
Right, measures as follows
ID of hole where bush fits is 38mm
ID of inner steel part of bush (Bolt hole) is 22mm, or did you want the bolt hole on the car.
The actual arm is difficult to measure unless you've got something in particular you'd like measured. Almost everything is on an angle, so it's hard to get a referance point.
However the ruler in the pic is a 300mm one, so hopefully that helps?
Let me know if you'd like any more measures and I'll see what I can do. If you want a pic with more detail I can email what I have.
Jeremy
Jeza ·
Another Pic - slightly closer up, also terrible quality, esp when you get to less than 50k.....
