Bizarre wrote:Anyone got a picture of the inner door with the panel off??
I replaced my door panels the other day because they were cloth and getting dirty.
Turned out to be water coming through. I refixed the plastic that had been torn over the years, but my new panels are wet again.
Yes its been pissing down unnaturally here in Sydney, but my car lives outside 24/7 so I need it fixed
Also what plastic are you using.
I got a large black garbage bag and opened it flat but it seems the be coming through this?? porous??
Would like to see where it is stuck down in the middle to allow the door latch to pass through.
These are 1975 L bug doors if that matters
Barry
I think normally they used a clear plastic with adhesive [sticky] on one side and went over the outer door skin then the rubber/plastic plugs fitted all round... from memory
so no water can touch the door card...
I used thick clear plastic I found somewhere...
Jeffs idea is better...
inside the door... You would need to clean where you are going to glue it.. inside the door under the inner panel so all water drips down into the bottom of the door..
but the window winder is still a pain..!!
maybe back to the outer part of the door...
remember the original plastic was sticky ALL over..
and went right to the bottom... of the door card so any water would drip from Under the card...
just under the top of the door card and just to the bottom of the door card.. all stuck All over the door...
the water isn't coming in the 1/4 window??? common..
