steering shaft movement
https://forums.aussieveedubbers.com/threads/95914/steering-shaft-movement
homer ·
i can move the steering wheel in an upward direction. Is there a bearing on the shaft or an adjustment i can make? The car is a 74 beetle(non super)
grumble ·
The plastic bush that fits inside the bearing needs replacing.
are these bushes available in Australia??
Definitly not one of VWs brighter ideas going from a metal bushing to plastic.
This is what you need.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C16-111-535D
If the bearing is OK youj can just cut a strip of plastic sheet and feed it into the gap, Idid this with my sons bug years ago and its still working.
homer ·
thanks for the info guys.does that bush have a thick wall as the shaft seems to move at least 5mm.
It feels like alot when the steering wheel attached but it probably has bout a 2-3mm wall
