ClockworkMonkey wrote:I've noticed that after every time I go for a drive there is a little bit of oil on the ground. This might sound dumb, but is this normal? I'm planning to put a little more punch into my 1500cc sp but not sure if a leaky engine is worth working on. I never seem to have to fill much oil into it and there is no smoke or really excessive oil burning smell
Any thoughts?
most VW engines do leak oil due to the expansion & contraction
because they get so hot due to the air cooling..
its common for sump gasket nuts to leak..
I use a new gasket kit with new washers every time and most times they don't leak - other times they do
tappet covers need new gaskets as the gaskets get compressed by the tappet cover
My last ones lasted about a year before they started to leak
unless they are replaced each time the tappets are adjusted.
and they need to be replaced carefully with no old bits of gasket cement or gasket left and perfectly clean,,
I then use permatex gasket cement on the tappet cover and grease on the engine surface..
and fit them carefully, as the gaskets can move as You fit them..
and they never leak until the gaskets get compressed from the pressure of the tappet cover clamps..
and there are different quality/material gaskets..
once a tappet cover gasket starts to leak it can drip a lot of oil
push rod tube seals can also leak...
they can crack or just leak due to the pushrod tubes expanding and contracting.
I always use permatex gasket cement on both sides of these seals to stop any leaks...
Some people don't use gasket cement... and that is why they leak...
If the breather pipe is blocked- oil can be blown out of the crankcase and will come out from behind the crankshaft pulley
and even the dipstick hole..
the engine can also leak where the case is joined across the centre of the engine ... due to heat expansion..
so all these things can be fixed..
so, no problem with an engine rebuild due to oil leaks..
PS: If I have an oil leak.. I degrease under My engine with spray can of foaming engine degreaser then hose it off..
