The front RHS brake cylinder seized with the pad against the drum.. I managed to get the drum off but in the process broke the ‘piston’ that pushes the shoe against the drum.
Does anyone have a piston they want to sell me?
I also need a set of rubbers both internal and the external boot for both brake cylinders
Can you suggest where I could get such??
I am based in Sydney not that that matters much.
Send me a PM or reply here.
Put two new wheel cylinders on the front. Reasonably priced, even German ones are only around $50 each. Vintage Vee Dub can help with parts.
HappyDaze ·
Agree with Matt. If the piston broke [sounds like me], the cylinder is probably damaged too.
Why not check ALL cylinders while you're at it, including the master.......a lot cheaper than panel work.👍
strex ·
I don't understand what you mean about wheel cylinders - Do you mean actually replace both pistons and housings as in the unit that recieves the brake fluid ?? So these are roughly about $50 ea?
strex wrote:I don't understand what you mean about wheel cylinders - Do you mean actually replace both pistons and housings as in the unit that recieves the brake fluid ?? So these are roughly about $50 ea?
Correct
1500S ·
Still got the Notch Strex!! I didn't think the wheel cyls were still available for the 64 on drums. 2 years back I couldn't get any. I bored and sleeved them with stainless. Rubbers are available and I might have some pistons still. I can help you out but I'm around West OZ at the moment and won't be home for around 5 weeks.
DH
strex ·
Sill got the Notch but never drive it .. Yep cant get parts anyware .. Tried brake shops and VW outlets .. I am waiting to see if Classic VW have a matching replacement cylinder kit - Should know by Tuesday .. Fingers crossed or I may have to wait for you to get back from WA.
mmm didn't notice the early notch description.....have you tried Vintage or Volksbahn?
vlad01 ·
try vic at vicsbahn. He has heaps of NOS parts and some type 3 stuff
strex ·
vicsbahn or volksbahn? Got a number?
dragsters for life ·
strex wrote:vicsbahn or volksbahn? Got a number?
i wouldnt bother with waiting on vlad to help his full of bollacks to start with
9789-1777
HappyDaze ·
Took you a while to remember the number, Dave.....you're slipping.😂
strex ·
Just wanted to give a huge thanks to Mick Motors in Brisvegas ... I got a reconditioning kit for my brake cylinder and the Notch is now alive and well again .. Thanks Mick
