2054cc ENGINE , HYD CAM
https://forums.aussieveedubbers.com/threads/96217/2054cc-engine-hyd-cam
RodPenrose ·
I have a brand new engine I have just assembled that will suit any type 1 , early type 2 and all type 3 vehicles . This is assembled using all 100% brand new components and here is the following details ;
Magnesiun universal AS 41 case opened for 94mm
Forged cro-moly 74mm 4340 race crank
5.4" I beam conrods with 3/8'' ARP bolts
AA 94mm piston/barrel kit
Mexican heads with 40 x 35.5mm stainless valves 47cc chambers
German type 4 hydraulic lifters
Webber hydraulic camshaft [ similar to Engle 110 ]
Scat aluminium cam gear
Shadek 30mm oil pump
Scat moly head studs
Scat crank gear kit
Stainless pushrod tubes
Forged cro-moly lightened 8 dowelled flywheel
Scat solid shimed rocker with swivel feet adjusters
Manton cro-moly pushrod kit
Forged cro-moly gland nut
This engine is 100% brand new and is complete from the front pulley to the flywheel and from valve cover to valve cover . This engine will need twin carbs that are also available , This should be good for about 78 hp and has a compression ratio of 7.75:1 and should be pretty much maintanance free . This engine is priced @ $ 4850 and is available for pick-up From Wollongong NSW , or can be shipped Aust. wide , ROD , 02-42729920
RodPenrose ·
This engine is still here and I would like to throw in a set of 40mm Kadron carbs/manifolds/airfilters and linkage to sweeten the deal as I need to make some more space , ROD.
