I have a brand new 1916cc engine here that has been assembled using all brand new parts . This engine has a compression ratio of 8.20 : 1 and will fit any type 1 , early type 2 and any type 3 vehicle . This engine is complete from the front pulley to flywheel and from rocker cover to rocker cover . Here is a list of components that went into this engine ;
Magnesium case
cro-moly 69mm 8 dowelled crank
I beam rods with ARP bolts
lightened 12 volt flywheel
40 x 35.5mm stainless valved brazillian heads with 57cc chambers
Engle W 100 cam
Engle lifters
Aluminium cam gear
stainless pushrod tubes
shadek 26mm oil pump
94mm piston kit
solid rocker kit
swivel feet adjusters
Scat stainless valve covers
This engine is priced @ $ 4500 and is located in Wollongong NSW and can be either picked up or delivered Aust wide , ROD , 02-42729920 .
RodPenrose ·
