Morning all,
Whats the real story with the swing axle seal kits?
They are supplied with 2 x paper gaskets, which would make you think that one of these fit either side of the backing plate. In my experience they dont actually fit on the back side of the backing plate (between backing plate & axle).
Are they both supposed to be fitted on the outer face of the backing plate? I have a bentley manual that shows 2 different variation of the exploded view.... one with gasket positioned between the backing & axle...... and the other shows the gasket postioned between the backing plate & the outer seal carrier.
Should they have aviation sealant applied to them or applied dry? (I have also seen a video showing them being greased before they are put on???).
http://www.justkampers.com/videos/watch/rear_hub_reassemble
Or can they be left out altogether.....with sealant used instead.
Have done a few searches & there seems to be conflicting versios of the hows & why's?
Tahnks in advance for you help
Brendan
Special Air Service ·
