Can anyone tell me where I can source this part from. It's a fuel line grommet that goes into the transmission tunnel. I've searched loads of catalogs but no one seems to have them. FYI this is from a 76 beetle.
Any help appreciated.
Cheers cam
cam070 ·
Anyone have any ideas?
FYI this grommet is located goes into the tunnel just next to the master cylinder.
Mr Muppet ·
Why don't you try Supercheap or Repco ect. they sell generic rubber grommets with or without holes of different sizes.
They are normally with the assorted nut and bolt packs.
Lucky Phil ·
I bought a few from CIP1 recently but they look a bit different to that one. These were round, while yours looks more oval shaped.
The US is a long way to source a coupla bits of rubber. The shipping will be a killer.
pPlenty of options, surely.
How 'bout an inch of 5/16 fuel hose split lengthways and held in with a cable tie?
Its oval shaped too fit a hole that was designed to accommodate 2 EFI hoses. The same bung was used on the chassis forks as well. I might have a 2nd hand one laying around. Or as lucky Phil said above with some non acid silicone to seal it up.
cam070 wrote:Anyone have any ideas?
I thought it was in the front..lol
under the fuel tank...
when You said tunnel I presumed You meant rear of the car
robb ·
go have a look in clark rubber they have all kinds of little type gromments
cam070 ·
Lucky Phil wrote:I bought a few from CIP1 recently but they look a bit different to that one. These were round, while yours looks more oval shaped.
Hi Phil,
Yes mine is definitely oval in shape and I've checked the CIP catalog and just returned from the US with another bag full of parts from them and others!
Cam
cam070 ·
1303Steve wrote:Hi
Steve, if you have an old one lying around that cpould really help me out. And although mine is only for a single hose your explanation makes sense. And FYI I will be modifying the grommet for 2 fuel lines for EFI. Cheers
Cam
I have one, its still in the pan, I will try to did it out and let you know.
Got it out OK, PM me and we can sort out getting to you.
