Splitty bits
https://forums.aussieveedubbers.com/threads/96339/splitty-bits
schnidlee ·
61-63 "humpback" seat back. Sides and top of frame are super solid, bottom of frame has some rust, it is just s straight piece of tube so a simple repair. cover is reasonable with busts in seams, ok for a rat but would be best recovered. I have the base too but there is NO frame just the springs and cover but realistically better sourcing a new base. $250.
Contact Matt on 0411103556, i'm in Adelaide 5050.
schnidlee ·
Passenger side door from a 61. Includes window frame, glass and mech. Window frame pretty rotten but door is solid except for bottom couple of inches and some rust in frame near rear window frame post (in pics). Hinges are there (still have some of the A-pillar attached. $120.
OG front floor mat. Has a few small tears and some stains from bits of rusty metal sitting for many years. Has only had a quick scrub but should come up much nicer with a proper clean. $60.
schnidlee ·
Un-hacked panel van Cargo doors from a double door (driver and passenger side doors). Both sets very straight with some rust in bottom 3-4 inches of skins and frames, otherwise good condition. $300 per set.
Passenger side
Drivers side
schnidlee ·
61 Engine lid. Rust in bottom 2 inches of skin and frame with a few more small spots in the rest of the frame. There is a dent and some rust in the "bump" above number plate but overall very straight. Mech is there but will need soaking as it is seized. The right hinge has been re-welded on at some stage, functional but not aesthetically ideal. $100
