Model: 2000 Nissan Skyline ER34 25GTT Project Car
Colour: Dark Blue Pearl (BP9)
Transmission Type: Manual - 6 speed
Registration Number or VIN#: 6u90000er34029329
Mileage: 39000 KMs
Price: $25k ono
Other Information: (PM me for the car build thread as it is on a different site)
I purchased this car last year with plans on finishing it, but.... it has to go.
Car comes with:
350Z 6 Speed Manual with heavy duty clutch, Extreme flywheel and short shifter.
VQ30DET NEO (30000km on the donk).
SOLD**2 x Ceramic coated Garrett GT2860RS (-5) Ball Bearing Turbochargers**SOLD
Shaved: Boot, door handle locks, boot rear light, rear boot lock & all badges.
Ceramic coating of parts mentioned eg exhaust, turbo's etc.
Custom 4" exhaust system (Same piping used on v8 supercars and NASCARS) with discreet dual tip and Metal Cat high flow cats. Custom Ceramic coated exhaust manifold and dump pipe.(Ceramic coated from dump to cats) [All ceramic coating by Chris at Craved Coatings in a Satin Black finish].
APS 350Z Twin Turbo Inter-cooler.
Brembo F40 Front Brakes: - Brembo F40 Calipers
- ENDLESS Brake Pads
- 343x32mm RDD Rotors
- RDD alloy radial mounts
- Braided lines
- Calipers have had a seal kit and have been powder coated gloss black.
Tein Mono Flex Coil over suspension.
Volk CE28N Wheels :- 18 x 9.5" Volk CE28N +22 (Professionally rubbed back, primed and refinished in high quality Glasurit 2 pack with a german clear coat to get the high gloss finish).
Genuine 'Altia' front bumper. Bumper in average condition.
Re-sprayed engine bay and plastic engine cover by Naz @ KMF.
Powder coated rocker covers, coolant pipe and alternator (Silver).
Genuine Nismo RB25DET engine mounts.
Factory front guard and engine bolts replaced with hex head bolts.
Re-trimed door trims from cream to black suede.
Internal trims (gear shift surround, door switch surrounds, air con, air con vents, etc.) painted satin black.
HKS Half cage.
All that remains to be done to be completed, is wiring (Pretty sure the VQ loom is in a box), radiator, seats, drive shaft and engineering. Engine is in but not ready to run, as all the fuel lines and misc parts are in a box.
Manny more parts included, such as a Trust 'Grex' remote oil block adapter, Custom aluminium intake plenum (Unsure of origin). 2 x Spare Heads - Port & Polished. Heavy Duty valve springs. ARP head and main studs. O2 sensors. Gasket set. Old rear suspension and more bits and pieces.
Well over $35000 spent not including the car value.
Not interested in parting out at this stage. Would like to see it go to a good home and get the attention it deserves.
Not included in the sale is the Focal speakers (As seen in thread).
Pictures:
Brakes:
Engine Bay:
Engine mounts and studs:
Turbo's:
Exhaust and Headers:
Gbox:
I/C:
Suspension:
Outer:
Inner:
Heads, Gaskets and Engine bits:
Intake:
I can be contacted at everlastingimages@gmail.com, or on 0407 610 133 (Phone not on during working hours but will check after 4.30 PM)
Contact: Neil
Email: everlastingimages@gmail.com
Phone: 0407 610 133 (Phone not on during working hours but will check after 4.30 PM) or send text and I will call you.
Need it gone to fund 2 x Beetle projects 😂 😎
Will consider swap for Splitty Bus or an Oval with cash.
68Volkaru ·
